Sticker Shock..........
/ Sticker Shock.......... #1
gltrap54
Topeka,KS
B3200 Kubota
Broke a hanger bracket on my 6' MMM....... B3200 has 400 hours & most of that is mowing, so who knows how I managed to break a weld on steel plate. Dealer wants $120 for a new bracket & of course they'd have to order it...... I think I'll see if it can be re-welded....... :D
/ Sticker Shock.......... #2
If you weren’t so far I’d say bring it over and I’ll weld it. Worst case send it to me in a flat rate shipping box and I’ll send it back in a day or two. Hopefully someone up there would do it though. Easy fix though
Brett
Thanks Brett! I've got a local welder that does good work at a reasonable price but I couldn't catch him in his shop today........
/ Sticker Shock.......... #4
Looks like very little penetration on the factory weld!!!
/ Sticker Shock.......... #5
yep - looks like it got a bad factory weld, at least it should be an easy and fairly inexpensive fix.
Yuuup........ What little welding I've done (ie stick/gas in HS circa 1970) I was pretty sure the horizontal weld was bad.....
/ Sticker Shock.......... #7
Should be an easy re-weld. I doubt you'll need to mow the lawn for a few weeks, huh?
Probably cost you as much for a can of matching paint as for the welding.
Ron
/ Sticker Shock.......... #8
That is REALLY cheap as far as parts go. Any reasonably good welder can make that BETTER then new.
/ Sticker Shock.......... #10
it's the very expensive orange paint they put on it. :)
My Kubota hat cost me about $20k, but it came with a free tractor.
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
John Deere Z994R (A60462)
John Deere Z994R...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
