Sticker Shock..........
/ Sticker Shock.......... #1
gltrap54
Topeka,KS
B3200 Kubota
Broke a hanger bracket on my 6' MMM....... B3200 has 400 hours & most of that is mowing, so who knows how I managed to break a weld on steel plate. Dealer wants $120 for a new bracket & of course they'd have to order it...... I think I'll see if it can be re-welded....... :D
/ Sticker Shock.......... #2
If you weren’t so far I’d say bring it over and I’ll weld it. Worst case send it to me in a flat rate shipping box and I’ll send it back in a day or two. Hopefully someone up there would do it though. Easy fix though
Brett
Thanks Brett! I've got a local welder that does good work at a reasonable price but I couldn't catch him in his shop today........
/ Sticker Shock.......... #4
Looks like very little penetration on the factory weld!!!
/ Sticker Shock.......... #5
yep - looks like it got a bad factory weld, at least it should be an easy and fairly inexpensive fix.
Yuuup........ What little welding I've done (ie stick/gas in HS circa 1970) I was pretty sure the horizontal weld was bad.....
/ Sticker Shock.......... #7
Should be an easy re-weld. I doubt you'll need to mow the lawn for a few weeks, huh?
Probably cost you as much for a can of matching paint as for the welding.
Ron
/ Sticker Shock.......... #8
That is REALLY cheap as far as parts go. Any reasonably good welder can make that BETTER then new.
/ Sticker Shock.......... #10
it's the very expensive orange paint they put on it. :)
My Kubota hat cost me about $20k, but it came with a free tractor.
/ Sticker Shock.......... #11
Way better than new. That looks like a typical cold weld. Even a hack welder like me can do a better job than that.
/ Sticker Shock.......... #13
rustyshakelford If you weren’t so far I’d say bring it over and I’ll weld it. Worst case send it to me in a flat rate shipping box and I’ll send it back in a day or two. Hopefully someone up there would do it though. Easy fix though Brett[/QUOTE said:
Just another good TBN'er. :thumbsup:
/ Sticker Shock.......... #14
Also have other weld check.
/ Sticker Shock.......... #15
Sand blast both pieces and assume that all the welds need to be beefed up.
/ Sticker Shock.......... #16
Did the base metal shear right off? It's hard to tell from the photo if the break is "ball in cup" or base metal brittle shear/fracture.
If its the first break type, re-welding will be no problem.
The second is indicating a whole different problem and you will need to be extra careful with pre&post heat when re-welding. I suspect this bracket isn't plain old mild steel.
/ Sticker Shock.......... #17
There are 2 breaks there:
1. The side brace (going roughly left to right on the piece that is flat on the truck bed in the picture, both sides are rusty) had no penetration and broke a while ago.
2. The main weld (going roughly up and down on the piece that is flat on the truck bed in the picture, both sides are shiny) broke just outside the heat affected zone from the weld due to the side to side flexing caused by the lack of support from the side brace.
Aaron Z
/ Sticker Shock.......... #18
I would never expect anything other than A36 grade mild steel in any farm equipment. Alloy metals are reserved for critical things like roll bars on racing cars.
The reason for breaking is typical of MIG welds that are improperly done, lack of penetration and cold lap.
I would definitely grind and repair the other weld while working on the broke one. It is likely of the same quality. I would grind off one side completely, reweld, then grind off the other side completely and reweld it also. Then you can put some of that expensive Kubota orange paint on and reasonably expect it to never break again.
/ Sticker Shock.......... #19
Yep. We see this all the time. Never properly welded in the first place. MIG guns are NOT hot glue guns. To weld means to penetrate the parent metal and liquefy it also. Not just stick hot cream up against it.
/ Sticker Shock.......... #20
I broke a weld on the deck wheel mount on my Kubota MMM. I just ground it clean and re-welded it (Arc) and sprayed it orange. Doubt I had more than an hour in it from start to finish and the metal was just normal mild steel. I won't expect yours in any different there.
2014 Dodge Charger Sedan (A61569)
2014 Dodge Charger...
2022 Schulte 2500 Giant Rock Picker (A56436)
2022 Schulte 2500...
2017 Bobcat T770 Compact Track Loader (A63118)
2017 Bobcat T770...
2014 Ford Escape SE SUV (A61569)
2014 Ford Escape...
2022 MORBARK EAGER BEEVER 1215 WOOD CHIPPER (A63276)
2022 MORBARK EAGER...
832781 (A61166)
832781 (A61166)
