Steering Issue on YM2000
/ Steering Issue on YM2000
Silvercoal are you sure it's not the right side where the woodruff key got stripped? That left side steering knuckle seems to still be a reasonable distance from the tire.
I just went out and looked at my YM240. The left front tire clearance to the steering knuckle is same as in your photo above. I would expect your tire to be scraping the knuckle, if the damage were on the side you photographed.
Well, I guess it's the right side if you're standing in front of the tractor looking at the nose. But from the seat, it's the left.
I double-checked that and I swear I can't see any change in the axle and tie rod assembly at all. I zero'd out the connector rod to the steering wheel, and all is as it should be. The only change is that driver side wheel being splayed out that 20 degrees.
Adams Tilt Trailer (A61307)
Adams Tilt Trailer...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A61307)
Case Wheels for...
USC Series 2000 Conveyor (A61307)
USC Series 2000...
SET OF (10) ACE CATTLE PANELS W/CONNECTION JOINTS (A60736)
SET OF (10) ACE...
1985 CADILLAC SEVILLE (A60736)
1985 CADILLAC...
UNKNOWN  20 FLATBED GOOSENECK (A58216)
UNKNOWN 20...
