Steering Issue on YM2000
/ Steering Issue on YM2000 #1
Silvercoal
YM2000
Hello, all, thanks for such a great place! I've got a YM2000 with the front driver's side wheel turned out about 20 degrees when I went sideways in a ditch. I've loosened the nut on the spindle the tire swivels on, but can't figure out how to get that tire back in alignment. Am I just not putting enough pressure on the wheel or is there something else I need to do to make the adjustment? Thanks again for any advice.
/ Steering Issue on YM2000 #4
Hello, all, thanks for such a great place! I've got a YM2000 with the front driver's side wheel turned out about 20 degrees when I went sideways in a ditch. I've loosened the nut on the spindle the tire swivels on, but can't figure out how to get that tire back in alignment. Am I just not putting enough pressure on the wheel or is there something else I need to do to make the adjustment? Thanks again for any advice.View attachment 742917View attachment 742917
There are parts manuals on pages 3 & 4 for your YM2000. They are added as attachments to each post where available.
The YM2000 came is 3 generations plus an odd YMG2000 generation that is far different.
On the engine plate or body plate, does it read YM2000A or YM2000A-A?
Grab those parts manuals, look them over and see how the front axle it put together. The diagrams are a huge help.
Is the tie rod (side to side) bent?
No, not at all. It's just like I torqued the wheel just enough to make it turn in the shaft. Everything looks normal otherwise.
After more research, thanks to your manuals, I've got my question more refined: How do I separate the spindle from the front axle assembly? I'm thinking of applying some heat to the crossbar to get it to expand enough to release the spindle. I'm pretty sure at this point that I've sheared the woodruff key inside the spindle. That's going to be a jammed in spindle.
/ Steering Issue on YM2000 #7
Careful with the heat, there is grease in there. Do not have a grease fire on your hands.
Take the wheel off, makes for easy access.
/ Steering Issue on YM2000 #8
Silvercoal are you sure it's not the right side where the woodruff key got stripped? That left side steering knuckle seems to still be a reasonable distance from the tire.
I just went out and looked at my YM240. The left front tire clearance to the steering knuckle is same as in your photo above. I would expect your tire to be scraping the knuckle, if the damage were on the side you photographed.
/ Steering Issue on YM2000 #9
Good thought.
So, lifting up the front axle getting the wheels off the ground and seeing what side has all the play.
Well, I guess it's the right side if you're standing in front of the tractor looking at the nose. But from the seat, it's the left.
I double-checked that and I swear I can't see any change in the axle and tie rod assembly at all. I zero'd out the connector rod to the steering wheel, and all is as it should be. The only change is that driver side wheel being splayed out that 20 degrees.
2014 Crossroads RV Elevation T/A 5th Wheel Toy Hauler Travel Trailer (A61569)
2014 Crossroads RV...
John Deere 4044R (A62177)
John Deere 4044R...
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
2011 Chevrolet Cruze Passenger Car, VIN # 1G1PK5S94B7295110 (A61165)
2011 Chevrolet...
2019 CATERPILLAR 289D SKID STEER (A62129)
2019 CATERPILLAR...
2018 Ford Ecosport SUV (A61569)
2018 Ford Ecosport...
