starting
/ starting #5
My tractor usually starts in the summer without glow plugs. We have several diesel lawn mowers, and they will never start without glow plugs. We had a case tractor, and you never had to glow plug that tractor/lawn mower to start it.
/ starting #6
Depends on the tractor. My small Ford 1215 I've had for 17 years will not start without pre-heat even when warm. The NH T4.75 starts below freezing without pre-heat.
/ starting #7
First start of the day? yes even in summer. Starts easier and you get a lot less smoke and I think less wear and tear on the parts.
/ starting #8
Usually give it five seconds in the summer for the first start. After warm don't need it. Winter 10-20 seconds.
/ starting #9
Well - that is a "every tractor is different" , oh and if you have a DPF:
Even though the engine is running and the glow plug indicator is not illuminated in the dash, the glow plugs will cycle anywhere from 3 to 5 minutes after start up. This helps reduce the amount of start-up emissions by 60 percent and also helps reduce build up of soot that would typically be trapped in the regeneration filter (DPF).
Automatically cycled glow plugs = longer times between regeneration.
I took possession of a 2015 Branson yesterday, and every time I have started it - the glow plug indicator illuminates, and it has not been below 50 degrees.
2014 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2014 Ford F-150...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A64556)
2016 Volvo VNL T/A...
2013 Ford F-350 4x4 Crew Cab Pickup Truck (A64556)
2013 Ford F-350...
2025 Wolverine PT-16-02C Class 2 Three Point Hitch Skid Steer Attachment (A64553)
2025 Wolverine...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
