Start it or leave it for spring
/ Start it or leave it for spring #41
Outside of cleaning radiators, etc., I don't think washing a tractor extends it's life or shortens it.
In regards to modern tractors, those with lots of electronics and plastic, the best thing an owner can do is protect it from the sun's rays when not in use.
My dad has always claimed a heavy layer of dirt is UV protection.
/ Start it or leave it for spring #42
guess I'm just a whiner./wimp. I hose all the mud, grass clippings and such off the tractor grease and spray bare steel with fluid film, tear down the Stihls and blow them off, drain the chain lube or it will leak out all over anyway, 2 stroke gas and use it in the gas auger for ice fishing.. I guess I just like not getting filthy just climbing on or using a machine and it shows me whats weeping, leaking, get the big wads of grease off. to each their own.. I like having all my stuff under cover, its not heated but I think it helps stuff last a bit longer. I also believe the UV is a killer of equipment...
/ Start it or leave it for spring #43
My 2N ford is 72 years old & been outside dirty most of its life.
I have no idea how long it will survive but I'm sure I would never be able to take advantage of the extra lifespan if I had garaged & washed it daily.
/ Start it or leave it for spring #44
Gotta pile it on pretty deep to cover the things that need the protection the most. :)
/ Start it or leave it for spring #45
I agree.
Not happening with a newer, more complex tractor.
/ Start it or leave it for spring #47
/ Start it or leave it for spring #48
People ......"will be buying new batteries all the time"
Really?
I leave cars, trucks, boats, tractors, mowers unattended for 6 months each year.
I am NOT.... "buying new batteries all the time".
I use Battery Minders/ Tenders/ etc., and my batteries usually last at least 8 or 9 years.
Sorry for my delayed response to your effort to de bunk what I know to be true....
LOL....x 2 :confused3: :dance1:
I ran a business on this very type of thing, anyway, you may want to re read your own de bunk writings, you may notice, your hardly doing nothing to keep things maintained...... :D
Charging batteries is not "nothing"......
But, in a free country, your able to believe that leaving things for long periods on a regular basis has no ill effects on anything. As long as I have convinced you charging your battery is not actually leaving it for long periods to discharge and have the wrong kind of reactions.
/ Start it or leave it for spring #50
My tractor is in my non heated shop (seldom use in winter, mostly mowing and spraying in summer), I have the clutch pedal locked down and a few times during the winter, I start the tractor and let it run at 1500 rpms for 30 minutes or so. I turn the PTO on (I can let the PTO run when off the tractor by lifting the seat).. It comes up to operating temp.
/ Start it or leave it for spring #51
Getting back to the original question... I am in a similar position as I am going down to use my late father's L2800HST which hasn't been run since August. It has a full tank of summer fuel so I am bringing my siphon hose, an empty diesel can and one full of winter grade fuel; my bottle of white Power Service which I will leave there, and a bottle of Bioclean. Also my booster cables although I won't need them.
It's in the unheated barn cellar which stays surprisingly warmer than the outside temps, although not above freezing. The temp isn't supposed to be above 20 degrees F that day but I don't expect any problems running it. It will take me about 2 hours to get the driveways plowed, so it will be good exercise for the tractor.
1996 International Water Truck with a Caterpillar Engine (A63688)
1996 International...
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A62129)
2005 CASE 580...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2019 Mirage 20' x 8.5'  Enclosed Trailer (A62613)
2019 Mirage 20' x...
2015 Case TR320 (A64126)
2015 Case TR320...
New Carbon Steel 4.75-12T Shackles, 38 Total (A62679)
New Carbon Steel...
