/ Stalling Engine #1
FracKen_A
Summit TX25, Ford 2000
So, just bought a summit tractor last week as Atwoods. Has been an amazing addition to my 66 Ford 2000.
Today something went haywire though, I was driving and it started sputtering, then died. Now it won’t stay running, and when it does start idling, it won’t rev up. I checked fuel level, gauge shows 3/4 full, but verified in the tank and added about a gallon for good measure.
While adding the fuel I spilled some, so I grabbed the hose and washed it off, while I was there, I hosed all the dust off of it and inside the engine bay. After that, it start up and acted normal, for about 5 minutes.
So I started thinking overheating, let it cool and checked the coolant levels. All normal.
It still only has the fuel in it that came in it from Atwoods and the gallon I added.
And of course, once I decided I needed to talk to summit. That had closed 11 minutes before I messaged them. Story of my life. Lol.
Does anyone have any ideas of things to check on this? If it were a gas engine, I would be golden, but diesel is a new part of my life.
Surely the two fuel filters wouldn’t be clogged a week after purchase, right?
/ Stalling Engine #2
My first thought is bad fuel, or gas got added accidentally. Possibly clogged fuel filter.
If it were me, I’d drain the fuel tank, change the fuel filter, and see what happens.
/ Stalling Engine #3
Hi Ken, we can certainly appreciate the lengths you went to troubleshoot this issue yourself. We have our ASM and Director of Parts and Service aware of this and they should be reaching out soon to help. Thank you for your patience! We'll get you back up and running asap.
- The Summit Tractors Team
/ Stalling Engine #4
WHAT!!!!! :D Service after the sale? I thought that was a thing of the past. Kudos Summit (y)
/ Stalling Engine #5
my summit tractor wont pull a 2or 4 % grade in high range.i'm talking moving from one place to another on the road not in a field.it sucks having to stop put it in low and get up the hill and stop put back in high go 100 yard and do it all over.this is the first tractor i've had to do that with .my RK19 doesn't do that my cousins kabota doesn't and it's a 26 hp .any help would be appreciated thanks in advance
/ Stalling Engine #6
Does it happen to have the parking brake engaged? If not, make sure it disengages fully.
/ Stalling Engine #7
no luck i just checked the brake and tried the hill same thing runs out of power and feels like the transmission is slipping
/ Stalling Engine #9
That doesn't right, even for an HST tractor.
Might be time to contact the dealer and explain the situation.
/ Stalling Engine #10
Did you get this resolved?
/ Stalling Engine #11
Checking to see if you got help? I have seen this on Solis Tractors and it points to fuel but turns out it's the crank sensor. Check and make sure it's good.
If you need help let me know. I'm the Texas Territory Manager for Solis.
/ Stalling Engine #14
Hi there, our area service manager has asked What rpms are you running at? You need to be wide open throttle. Our tractor is also larger size and heavier for stability.
/ Stalling Engine #15
wide open throttle.they took it in and adjusted the forward foot pedal it wasn't get full travel.it's better for sure but still not right but i'll adjust to it
/ Stalling Engine #17
When an HST Tractor slows down the driver tends to push the speed peddle harder…like an accelerator. Wrong!!! Ease up on the peddle and it will reduce speed but continue forward with power unless it’s extremely steep.
This is both true and not well known; hell, I'm pretty sure I learned about it on this forum.
/ Stalling Engine
Sorry, notifications for this entire thread just got my inbox all at once, months later. lol.
Yes summit worked with me, even sent a service manger to look at it. No one could find anything wrong, everything looked good. One day when it happened they had me verify an electrical connection again, that both they and I had checked several times. As I was pulling it apart, one of the pins slipped out of the connector.
New wire harness and all was grand. No problems since.
/ Stalling Engine
Yes I did. Turned out to be a loose pin in the fuel pump wire harness.
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
Ford F-450 (A63689)
Ford F-450 (A63689)
2004 BMW 325ci Convertible Coupe (A62613)
2004 BMW 325ci...
Steiner 450 (A64126)
2017 Ford E-Series FedEx Delivery Truck, 5.4L V8, Step Van Conversion (A63689)
2017 Ford E-Series...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
