Stack??
/ Stack?? #1
Brockwaykid
Granville NY
John Deere 317 (KT17 SII)
Hey everyone, I have been thinking about building a stack for my 317, but i'm unsure of how I can make an elbow. I'm pretty sure exhaust pipe is 1 1/2. We have tons of pipe at our shop, I'll have to find some. Any ideas if how i could make one? Or could I get one at TSC for example??
/ Stack?? #2
To make the ell, you will need access to a tube bender. Since you don't have one, most all muffler shops will have, and I would guess they wouldn't charge more than a few bucks to bend your tube. I would get there first thing on a weekday morning when they would generally be less busy.
Lay everything out before you go. They should also be able the expand the ends if you are doing a clamp system. If you are TIG welding, then obviously you won't need the ends expanded.
/ Stack?? #3
You can use electrical conduit. Find a contractor (yellow pages) and ask about scrap peices. A lot of times they have 90 and 45 degree bends in various size after jobs are done and clean-up taken back to shop.
It has a galvinized coating and will need to be sanded off before weldind, but will not rust.
/ Stack??
I have a design i made up, its all good now!!
2021 CATERPILLAR 259D3 SKID STEER (A62129)
2021 CATERPILLAR...
2017 Bobcat T770 Compact Track Loader (A63118)
2017 Bobcat T770...
Rotary SPOA9-200 Automotive Lift (A56857)
Rotary SPOA9-200...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
DEUTZ MARATHON...
