Posthole Digger Speeco PHD Adapter
/ Speeco PHD Adapter #1
Zoombah
Central Texas
I have an old PHD that appears to be a Speeco. Works fine, no leaks. I need a new auger bit but all the auger bits I see require a 2" output shaft on the PHD whereas the output shaft on my PHD is only 1 3/8". Anyone know of an adapter that can fix this situation?
I did email Speeco. They promptly responded back but unfortunately they do not sell an adapter. I think the standardization to 2" must have occurred quite a number of years ago because I've seen nothing less than 2" on any website that deals with PHDs.
/ Speeco PHD Adapter #4
Wouldn't an adapter simple be a tube with an OD slightly smaller than 2" and and ID slightly larger than 1 3/8" with a hoel in it. If you can't find one, any body with a machine shop or even a drill press ought to be able to make one easily.
Andy
/ Speeco PHD Adapter #5
If you are going to make one use a tough steel. Like 4140 . I made one once from cold rolled and it had some problems. Can't remember exactly what though.
/ Speeco PHD Adapter #6
Sorry about that, I was not talking about the adapter. Doesn't Speeco sell new auger bits (and/or replacement tips) for your PHD? ...they should be 1-3/8"... or did they change over to 2" also?
Speeco no longer makes anything in 1 3/8"....not even an adapter.
Yes AndyMa, what you described is about all there is to it. The only hangup I can think of is the wall thickness which would need to be around 1/4".
John Deere LX5 5ft. Rotary Brush Cutter Tractor Attachment (A61572)
John Deere LX5...
2012 Ford Expedition SUV (A61574)
2012 Ford...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
1000 Gal Tank (A64119)
John Deere 7000 4R Wide Planter (A66285)
John Deere 7000 4R...
Can Am Defender (A63688)
Can Am Defender...
