Socket wrench for square head machine bolt
/ Socket wrench for square head machine bolt #1
flusher
Super Member
Sacramento
Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
Anyone out there know where I can find a socket made specifically for a square head machine bolt that is 1" square?
I'm renovating an old offset disc and these square head bolts are inaccessible to a cresent wrench or an open end wrench. Don't want to use a standard socket since I suspect that all I'll do is round off the corners of the nut and bolt head.
/ Socket wrench for square head machine bolt #2
I'm no help with finding the correct tool, but it sounds like something I'd just cu t off and replace with something less problematic.
/ Socket wrench for square head machine bolt #3
Do a Google for "8 point socket"
/ Socket wrench for square head machine bolt #4
Snap-On makes them. Look under 1/2 drive special purpose. I believe they are called Double Square, and I know they are expensive. Did you try Tractor Supply they sell inexpensive tools. Greg
/ Socket wrench for square head machine bolt #5
SNAPON part number P432 1" shallow part number SIPR432 deep well or make your own out of some 1 or 1 1/8 square stock. How about a 1" drive extension, put the female side on the nut then put a wrench on the male.
/ Socket wrench for square head machine bolt #6
Know anyone that runs a tire service? I think that's what they use to remove bud wheels.
/ Socket wrench for square head machine bolt #8
McMaster Carr has eight point sockets that will work.
/ Socket wrench for square head machine bolt #9
Afternoon Flusher,
You could use impact sockets also, you wont break them ! ;)
/ Socket wrench for square head machine bolt #10
Give Sears hardware dept a call.
larry
/ Socket wrench for square head machine bolt #12
I think you can use 12 pt. sockets on square head bolts and nuts. Tey would be cheaper than anything else more than likely.
Solo
/ Socket wrench for square head machine bolt #13
All you will do with a 12 point socket is round the head off. Not enough contact area. Get the proper 8 point socket. Last time I checked Sears still offered 1/2 inch drive Craftsman 8 point sockets. Think I might even have some in one of my tool box's.
/ Socket wrench for square head machine bolt #14
According to this page of the current sears catalog, the largest 8 point 1/2 drive socket they offer is 3/4"
Sears
Andy
/ Socket wrench for square head machine bolt #15
The site AndyMA linked has one....for a mere $27 unless you need a deep one and they are $49 :eek:
/ Socket wrench for square head machine bolt #16
Unfortunately larger size tools tend to be more expensive.
Andy
/ Socket wrench for square head machine bolt #17
ANY 1" drive socket used backwards oughta work. You can use a couple hex nuts welded together to couple to the ratchet socket.
larry
/ Socket wrench for square head machine bolt #18
I may have one; I'll check tomorrow. If I do, and you can wait that long, I'll send it to you.
Thanks. No problem.
larry
Neat idea.
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A65053)
2018 JOHN DEERE...
New/Unused SDLGC80 4-Seater Electric Golf Cart (A65583)
New/Unused SDLGC80...
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A63569)
2009 VOLVO VHD...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
