Socket wrench for square head machine bolt
/ Socket wrench for square head machine bolt #1
flusher
Super Member
Sacramento
Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
Anyone out there know where I can find a socket made specifically for a square head machine bolt that is 1" square?
I'm renovating an old offset disc and these square head bolts are inaccessible to a cresent wrench or an open end wrench. Don't want to use a standard socket since I suspect that all I'll do is round off the corners of the nut and bolt head.
/ Socket wrench for square head machine bolt #2
I'm no help with finding the correct tool, but it sounds like something I'd just cu t off and replace with something less problematic.
/ Socket wrench for square head machine bolt #3
Do a Google for "8 point socket"
/ Socket wrench for square head machine bolt #4
Snap-On makes them. Look under 1/2 drive special purpose. I believe they are called Double Square, and I know they are expensive. Did you try Tractor Supply they sell inexpensive tools. Greg
/ Socket wrench for square head machine bolt #5
SNAPON part number P432 1" shallow part number SIPR432 deep well or make your own out of some 1 or 1 1/8 square stock. How about a 1" drive extension, put the female side on the nut then put a wrench on the male.
/ Socket wrench for square head machine bolt #6
Know anyone that runs a tire service? I think that's what they use to remove bud wheels.
/ Socket wrench for square head machine bolt #8
McMaster Carr has eight point sockets that will work.
/ Socket wrench for square head machine bolt #9
Afternoon Flusher,
You could use impact sockets also, you wont break them ! ;)
/ Socket wrench for square head machine bolt #10
Give Sears hardware dept a call.
larry
/ Socket wrench for square head machine bolt #12
I think you can use 12 pt. sockets on square head bolts and nuts. Tey would be cheaper than anything else more than likely.
Solo
/ Socket wrench for square head machine bolt #13
All you will do with a 12 point socket is round the head off. Not enough contact area. Get the proper 8 point socket. Last time I checked Sears still offered 1/2 inch drive Craftsman 8 point sockets. Think I might even have some in one of my tool box's.
/ Socket wrench for square head machine bolt #14
According to this page of the current sears catalog, the largest 8 point 1/2 drive socket they offer is 3/4"
Sears
Andy
/ Socket wrench for square head machine bolt #15
The site AndyMA linked has one....for a mere $27 unless you need a deep one and they are $49 :eek:
/ Socket wrench for square head machine bolt #16
Unfortunately larger size tools tend to be more expensive.
Andy
/ Socket wrench for square head machine bolt #17
ANY 1" drive socket used backwards oughta work. You can use a couple hex nuts welded together to couple to the ratchet socket.
larry
/ Socket wrench for square head machine bolt #18
I may have one; I'll check tomorrow. If I do, and you can wait that long, I'll send it to you.
Thanks. No problem.
larry
Neat idea.
2016 INTERNATIONAL PROSTAR 6X4 T/A DAY CAB TRUCK TRACTOR (A67147)
2016 INTERNATIONAL...
Eagle Weather Vane (A64557)
Eagle Weather Vane...
2022 EZ-GO ELITE...
2019 Cub Cadet Ultima ZT 1 50in Zero Turn Mower. (A64557)
2019 Cub Cadet...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2008 Ford F-250...
WESTINGHOUSE PORTABLE ARC WELDER (A64276)
WESTINGHOUSE...
