Snow Warning??
/ Snow Warning?? #51
Boondox - I don't have an answer to your problem of your chains icing up. I do have all 4 tires loaded with antifreeze so maybe the weight does make a difference, or maybe the R4's make a difference...
Corm
/ Snow Warning?? #52
Thomas - I think you're right. I don't know if the chains will make any difference today. I don't plan on moving my Cub till things soften up a bit. It's supposed to be in the 40's tonight with moderate wind, so with a little luck my icy driveway will turn into a slushy driveway, and that I can handle. I didn't even go to work tonight, didn't dare head down the hill...
Corm
/ Snow Warning?? #53
The weather this winter is getting ridiculous, isn't it? You've got ice, but expecting temperatures in the 40s tonight in Vermont. And our high for today was 70 (about midnight), got .41" of rain last night, and the temperature has been dropping all day so we're expecting a low of about 20 tonight (30 right now) in the middle of Texas./w3tcompact/icons/crazy.gif
And today was the day I intended to start planting the garden if it hadn't rained last night and the cold front hadn't arrived./w3tcompact/icons/frown.gif But at least the 50 to 60 mph winds and damage last night was all north of us.
Bird
/ Snow Warning?? #54
Well, we got our rain and ice the last couple of days. Wife stayed home today from work because allot to the roads were closed. So this evening I decided that it would be a good idea to remove all the slush from the driveway. Had about half the driveway done and rolling a big slush ball down the driveway. It was about half the size of the tractor and I thought this is great. Untill I got to the bottom of the drive and started up. No traction!!!/w3tcompact/icons/shocked.gif Now how to get the tractor home. Just in case I always stash a little sand and salt at the bottom of the drive. Sure comes in handy!!!/w3tcompact/icons/smile.gif When I had read some of the boards about ice I had my doubts but now from experience I can now understand. Sliding down a hill in a tractor will do that!!!/w3tcompact/icons/shocked.gif Even with chains on the back I couldn't get up the hill untill I put sand and salt on. Which brings up a good question. Do you put chains on the front also or do you stud your front tires? My neighbor works at the town barn and say's they stud all there tires. I've never heard of studding tractor tires with hex nuts. How about all of you?
Anyway got the job done and even dug out the neighbors.
Have a good night,
Al
/ Snow Warning?? #55
I hear ya, Bird --
Just last weekend at the property it was shirt sleeve weather all the way, and now I'm told my mom's doctor appointment was called on account of snow and ice. /w3tcompact/icons/tongue.gif
Down here in the S.F. Bar Area we're getting a pretty good rain -- finally! We were about 50% of normal rainfall up to this point, so we're glad to see it and hoping for more.
Hey, RobertN!!! You still with us? Is there enough snow on the ground to push around with a tractor?
/ Snow Warning??
What a change in weather. /w3tcompact/icons/shocked.gif
41 degrees wind gusting between 33 to 46mph sun trying to peek thru the cloulds,/w3tcompact/icons/smile.gifbut the weather station saying the temps will be in the single numbers and tomorrow in the twenties. /w3tcompact/icons/frown.gif
I'm hope the snow banks will settle and far as the ice,I better make a call and have the driveway sanded. /w3tcompact/icons/frown.gif
Be extra careful when out and about today.
Thomas..NH /w3tcompact/icons/wink.gif
/ Snow Warning?? #57
Al, on the CTB there was a considerable discussion awhile back about putting screws in tractor tires for studs. Apparently it's not that uncommon in some areas. Just have to put them on the ridges of the tread, not in between of course, and short enough to not puncture the tire. And 22 degrees here again this morning, but the sun's coming up, it's clear, and at least right now, almost no wind./w3tcompact/icons/smile.gif
Bird
/ Snow Warning?? #58
Alan,
I'd think the studs would be a good compliment with rear chains. they would give some extra bite for sure. The screw in studs used for motorcycle racing do look interesting. Wouldn't it be nice to have a second set of front tires all studded for winter use. /w3tcompact/icons/smile.gif
When I was at the Deere dealer yesterday to get my parts book (finally), we got to talking chains. For what its worth this is what I was told. They recommended against using them on the fronts, too much stress they said. Just my .02 cents. A subject of controversy for sure.
Thomas, the winds are howling here. Up to 40 mph today. 40 degrees right now. down into the teens tonight. All that water on top the ice makes it even worse. My yard looks like a ice skating rink too.
DFB
/ Snow Warning??
Just check the temp 21 degrees and at 11:30am it was 44 degrees /w3tcompact/icons/shocked.gif and still dropping.
Oh man oh man is the wind howling over here, /w3tcompact/icons/crazy.gif for I just finsh plowing 2/3 of my tree road and between the pine cones and small limbs are falling like rocks..ouch..yikes.
Thats what my dealer also said...not to run tire chains on the front,for its not good for the 4wd.
Kinda nice to have still light at 5:15pm /w3tcompact/icons/smile.gif
If there anything good about ice /w3tcompact/icons/frown.gif it would have to be one doesn't need power steering. /w3tcompact/icons/laugh.gif
Sure has been a wild weather week for us up here in New England,and I do hope next week will be a tad milder. /w3tcompact/icons/cool.gif
Better throw two logs on the fire tonight,sure going to be on the chilly side.
/ Snow Warning?? #60
Pretty wierd weather here in Michigan the past few days. Record temps in the mid to upper 50's yesterday with rain....lot's of rain. Then last night the temp dropped more than 30 degrees in two hours and it snowed an inch or so. Everything re-froze.
We've had about 2' of snow on the ground for the past two months and the ability to move around much outside has been kind of limited. Today was great. Got to get out and take a good long walk around the property and check out the limb and tree damage from the snow and ice. Not too bad, but some chain saw work is in order as soon as I can get a trailer around the place. The dog's pretty excited too since the snow has melted and what's left has turned hard......she can run around and maintain her "perimiter patrol" again.
Wierd weather. Only a high of 25 or so today and about the same for tomorrow. Maybe 40's by mid-week.
Bob Pence
GROVE RT 63S HEAVY DUTY HYDRAULIC CRANE (A60736)
GROVE RT 63S HEAVY...
2008 Freightliner Allegro Bay Class A Motorhome (A59231)
2008 Freightliner...
2018 23ft. Carolina Skiff Ultra Elite Boat with 24ft. T/A Boat Trailer (A59231)
2018 23ft...
(INOP) 2015 POLARIS SPORTSMAN ACE 570 (A59823)
(INOP) 2015...
500BBL SKIDDED FRAC TANK (A60736)
500BBL SKIDDED...
2000 Kenworth Tri-Axle Dump Truck (A59230)
2000 Kenworth...
