Snow Attachments Snow PUMP
/ Snow PUMP
While slowly also continuing the evaluation of a hydraulic solution I noticed that pumps such as (purely for the sake of an example) the Rexroth A4VSG 71 to 180 models which could conceivably play a role, the Volume-Control is by various electrical/hydroelectrical means. I don't see any 'plain-cable' notes. Anyone know how these controls are actually manipulated? I don't think I would want anything other than plain-cable.
https://www.boschrexroth.com/ics/cat/content/assets/im/A4VSG_MainPhoto_RGB.web.jpg
https://md.boschrexroth.com/modules...1AC8A43290.borex-tc&sch=M&id=12598,20,1158534
Just had a long talk about this with our local 'blacksmith' (pro welder & machinist) who has spent his life making things including every imaginable hydraulic contraption. His advice was very short: forgetitt!! Said he "you WILL at one point notice that what was throwing the snow 100 feet 3-4 years earlier is only throwing it 60". He took a huge bite out of my enthusiasm but he man has done miracles for me as well in the past and his opinion is very hard to challenge in my book. When I built the first rig I kind of dismissed hydraulics prematurely as I was pressed for time so this time around I really wanted to give it a fair chance ..but it looks like it might just become scene-1 take-2.
/ Snow PUMP
It's been -24c almost all the time lately, also had a couple of issues with the current blower, belt sprocket slipped & chewed 3/4" off the 5" belt width. Fixed that, then the electric power cylinder quit, the new one's on its way. It's been a heavy winter, already on clear-job #17 with 12 being a normal season. I'm casing a potential host truck next week (ram-1500 with 2500 springs, leaving me the option of upgrading to dana 60/70 axles). I looked at a dozen 3500 class trucks but those are always bought to do heavy work and the owners drive them into the ground before throwing them on the street. They all stickered 3-4 grand and needed another 5-6 to fix. This little 1500 is clean with low miles, a 4x4 on a 360 with auto. It isn't as big a rig as the others and can be upgraded to haul the weights. I'll know if I've got it mid-week.
/ Snow PUMP
Well, that was an exercise in futility, drove 400 miles not to buy a car! The Ram's frame was literally _flaking_ off.
On with other concerns. Which GM rear axle would have full-float support and available 3:42, and can one also get 3:42 in a full-float Dana like maybe a 60 or a 70? I'm looking at what $500 might do my 2003 Jimmy's rear load-bearing ability. In the front I think I might be able to devise a blower at under 700 lbs.
/ Snow PUMP
Too bad about your long trip.
The GM 14 bolt rear axle should work for you.
Pirate4x4.Com - Extreme Four Wheel Drive
Thanks, no big deal, the guy could have told me though as I had specifically asked him about the frame. I actually looked at two f350's as well but am going to give up on that. Anything worth trying is over 6-8 grand and anything in my 2-3 range is totally done for.
When I bought the jd-270 blower back in '08 I brought it home on a S-10 & bent an axle when I hit a relatively small bump. That has stayed in my mind because it wasn't mine. There's also the fact that I'd pay pretty much the same price for almost any axle 250-350 being about street for as-is. The Jimmy actually came with two ratios if I remember correctly so I should be able to change the front at least to one other. The actual ratio doesn't really matter as I won't be racing it :)
The rear curb/gros axle weight is 1806/2700 lbs so with a 1200 lbs engine + let's say a tranny, sprockets, or a huge pump I'd be pushing my luck. Swapping out the rear would be relatively easy and it would leave me free for problem-solving in the front where the number is a more challenging 2191/2500
/ Snow PUMP #166
Just for information, the weight ratings on the door sticker for my '73 Chevy 3/4 ton are:
GM 14 bolt full floating rear, 5560 lbs
Dana 44 front, 3500 lbs
/ Snow PUMP
Nice truck, you wanna sell it? :dance1:
I'm sure I'll find the right axle, all life is on hold right now just waiting for spring (another month). I also came across a couple of stateside links to outfits that actually sell kits to do solid axle swaps on the Blazer/Jimmy rigs. So far I've received no replies from either. These might be good solutions for the front, I'd just buy the bits and pieces and save on shipping by buying the axle locally. The thing is that if the rust-bucket I didn't buy is worth $2500 then my pampered and oiled-every-year Jimmy is worth $5000 but I can't even get $2000 for it. I can get a LOT done before even approximating the minimum 4-5 grand it would cost me to have a suitable and ready-for-service truck platform or 7-8 for one in the same shape as my Jimmy.
/ Snow PUMP #168
I did a little research on it. The guys doing 4bt swaps are running into this all the time. The statonary type governor is called a "RSV" while the road type governor is called a "RQV". Apparently it is a part of the injection pump and while it's separate, it's also part of the rest of the pump enough to where you have to know what you are doing to swap it out. Do a google search "RSV to RQV swap". Of course they want to go to the road governor, you want to go the other way.
Just did a bit of research for the neighbour who wants to convert an older tractor to a Cummins. A used RQV pump out of a Case tractor is $650 CAD. I'm pretty sure you could get that much on Kijiji for the RSV type injection pump that's on the motor right now.
/ Snow PUMP
I haven't yet investigated what exactly the truck type governor does, I don't see the need for it except as a cruise-control. The only diesel CAR I ever had was a rabbit. Maybe it's just to stabilize the rpm and prevent it from hunting every time you kick the pedal on a bump (my Cat-426 does this a lot). I still haven't started the engine up, just did clearing job #17 and there's a yard of snow in the fields ..we really need spring now to reverse the morale :dance1:
/ Snow PUMP #170
RQV governs the engine to where you set the throttle. In other word if you set the throttle for the engine to run at 1500 rpm the governor will attempt to keep the engine rpms at that speed within the limits of engine power. The RSV type governor which is what you have on the automotive motor governs idle and full throttle. In between is governed by the throttle pedal in the cab of the vehicle. So if your blowing snow at 1500 rpm and run into a heavier load the motor will slow down because the governor isn't reacting to the load. Conversely if the load lightens the engine rpms will increase. Whereas with an RQV style governor the injection pump will automatically adjust the throttle to try to keep the engine at 1500 rpm. Believe me you will be a lot happier with an RQV style governor.
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
DigiTrak Aurora AF8 Horizontal Drilling Display Set (A59228)
DigiTrak Aurora...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2007 Range Rover Sport AWD SUV (A59231)
2007 Range Rover...
1999 Ford F-150 4x4 Pickup Truck (A59230)
1999 Ford F-150...
