Snow Blower / Right Tractor
/ Snow Blower / Right Tractor #1
douguy
Deatsville, Al
JD1025r
I have been looking at a JD1025r to take to Colorado Mtns and do work and snow removal at my cabin at 9000 ft ele...Today I was told that the 1025r probably would not work well at that altitude and that I would need to have a tractor with a turbocharger...now we're looking at JD3036e which is alot more money....Do any of you have knowledge on this situation????
/ Snow Blower / Right Tractor #2
At higher elevation you pretty much need a turbocharged engine. A naturally aspirated motor will lose about 30% of it's power @ 9000 ft.
(HP X Altitude [in feet] / 1,000 X 0.03 - HP)
/ Snow Blower / Right Tractor #3
Interesting. Are gasoline engines the same way?
/ Snow Blower / Right Tractor #4
Yup. Fewer oxygen molecules per volume of air.
/ Snow Blower / Right Tractor #5
I knew you had to reject carbs, but I never thought there was less hp after that was done.
Sorry for the hijacking....
Sent from my iPad using TractorByNet
/ Snow Blower / Right Tractor #6
Yep, the air isn't as dense so there isn't as much oxygen per volume of air as sea level. A turbo can cram a greater volume of air into the intake than naturally aspirated can suck in so you get more oxygenation for combustion with a turbo.
Thanks..this confirms what I was told
New/Unused Outdoor Propane Patio Heater (A65583)
New/Unused Outdoor...
2022 EZ-GO ELITE...
NEW 2025 Trailer by Premiere 18'+2' Tandem Axle (A62679)
NEW 2025 Trailer...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
2024 JCB 35Z (A60462)
3pt Counter Weight (A64127)
3pt Counter Weight...
