Snow Blower / Right Tractor
/ Snow Blower / Right Tractor #1
douguy
Deatsville, Al
JD1025r
I have been looking at a JD1025r to take to Colorado Mtns and do work and snow removal at my cabin at 9000 ft ele...Today I was told that the 1025r probably would not work well at that altitude and that I would need to have a tractor with a turbocharger...now we're looking at JD3036e which is alot more money....Do any of you have knowledge on this situation????
/ Snow Blower / Right Tractor #2
At higher elevation you pretty much need a turbocharged engine. A naturally aspirated motor will lose about 30% of it's power @ 9000 ft.
(HP X Altitude [in feet] / 1,000 X 0.03 - HP)
/ Snow Blower / Right Tractor #3
Interesting. Are gasoline engines the same way?
/ Snow Blower / Right Tractor #4
Yup. Fewer oxygen molecules per volume of air.
/ Snow Blower / Right Tractor #5
I knew you had to reject carbs, but I never thought there was less hp after that was done.
Sorry for the hijacking....
Sent from my iPad using TractorByNet
/ Snow Blower / Right Tractor #6
Yep, the air isn't as dense so there isn't as much oxygen per volume of air as sea level. A turbo can cram a greater volume of air into the intake than naturally aspirated can suck in so you get more oxygenation for combustion with a turbo.
Thanks..this confirms what I was told
2007 John Deere 644J Articulated Wheel Loader (A59228)
2007 John Deere...
Case Titan 3530 (A63688)
Case Titan 3530...
1999 Nabors Chip Trailer (A62613)
1999 Nabors Chip...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
3 Point Plow (A62613)
John Deere 6110M (A64126)
John Deere 6110M...
