snow blade tilt?
/ snow blade tilt? #41
Regardless of whether you manually angle or power angle all snow plow moldboards should be tilted back at an angle of 21 degrees measured at the cutting bar which results in reducing the steering effort needed to control the vehicle. The 21 degree tilt of the mold board is allows the snow to actually roll more easily to the side. And I won't take any credit for this piece of knowledge since it was imparted to me by an engineer that worked for a major plow OEM. I met him while designing snow removal equipment for a major metropolitan agency. And unless someone has a heavy truck most light duty plow sales people are not aware of this angle setting. And looking at the photos in some of the posts shows the plows have no tilt back angle whatsoever! Hope this helps. :thumbsup:
That's an interesting (and potentially very valuable/often overlooked) piece of information.
/ snow blade tilt? #42
/ snow blade tilt? #43
I dont believe so. it had me stupmped for days until I read threads here.I would disconet the hoses and dump them in a five gallon bucket and then 'tilt' the tractor bucket lever and oil came out the one I thought it should and then curled back and oil flowed from the other, yet when I installed them it would turn one way and that was it.
even a double acting would accomplish the same thing.the two single acting ones are together like a double acting. But I belive not all tractors have this regen feature.Mine was a ford. I would ask someone at the dealership, as Im sure they deal with it all the time..
i know someone on here will be able to answer more specfically on your model..
perhaps this link will help.
http://www.tractorbynet.com/forums/showthread.php?t=9403
2016 INTERNATIONAL PROSTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2016 INTERNATIONAL...
2015 Chevrolet Caprice Sedan (A61569)
2015 Chevrolet...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2020 John Deere 6120M (A60462)
2020 John Deere...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
SDlanch SDLGC80 (A60463)
SDlanch SDLGC80...
