Smart Home Wiring
/ Smart Home Wiring #21
How is it cheaper to use wireless? Most 100MB network cards are now around $25.00 and if you have only two computers, you do not even need a hub, just a crossover cable. Maybe for three, the cost of wireless would be close, as hubs go for around $80 for a 8 port 10/100 hub. Still I would prefer to have the wired system for the performance of it. IMHO, wireless is best reserved for laptops where the portability factor plays in, not for desktops. Kind of like the cordless mouse... Most of the times I use the mouse, I am right there in front of the computer, not needing to use the mouse from across the room, I see little benefit for the added cost / complexity of a cordless setup.
/ Smart Home Wiring #22
Re: Wireless gear...
On many wireless systems speed is a function of distance from the base unit. The convenience you think you're getting may cost you dramatically in SPEED.
/ Smart Home Wiring #23
Rob, the type of metel plaster rings would be the type you would install on a metel 4" sq. box. I have also taken the plastic single gang nail on and cut the back off, the reason for this is, terminations on these cables extend out from the back of the face plate enough that it puts to much tension on the jack and you also must remember that it is recommended that 12" to 18" of slack should be left on each cable,to correct any wiring mistakes or to upgrade any terminations in the future, so with this slack and the jacks and/or connectors you can see why the box can be to small. If you are thinking not using a box is shoddy, it is not it is a common practice. I have had to use boxes on projects that have spec"s requiring them, it can be done. If you decide to use them use 4"sq. x 2-1/8" deep with the proper plaster ring. Good Luck, Chuck
/ Smart Home Wiring #24
As well as Leviton, check out these links:
<A target="_blank" HREF=http://www.nordx.com/public/htmen/15_0.htm>Nordx CDT</A>
<A target="_blank" HREF=http://www.onqtech.com/>ONQ Tech</A>
<A target="_blank" HREF=http://www.homecabling.com/hcnew/default.asp>Siemon Home</A>
<A target="_blank" HREF=http://www.unicomlink.com/solutions.html#residential>Unicom</A>
Hope this helps.
Paul
/ Smart Home Wiring #25
Rob, if keeping up to date is really important, you might consider doing a portion or all of your media wiring with ENT. ENT is electrical non metallic tubing, it is typically blue and is corrugated. It is a snap to use, wires pull through it very easily. Use at least 3/4" pipe or larger. You can buy it in 10' lengths or 100' rolls.
The reason for using a conduit method is that its just a short matter of time before Cat6 and Cat7 twisted wire is made available. Without knowing where we are headed for sure, (Al Gore isn't giving us any news about whats going on) knowing that you have a pathway to pull new wire is going to be a bonus. When I do my home, I will use ENT for all the media wiring. Wireless may well be the future (ie Bluetooth), but if its not, you will be prepared. Rat....
/ Smart Home Wiring
Excellent, thanks Paul. I picked up my Cat5E, RG6QS and 12-2 speaker cable yesterday at Home Depot. Hope to be pulling wires this weekend and now that we're under roof I don't have to say "weather permitting". Other than if the weather is nice I'd sure like to get some tractor time in /w3tcompact/icons/smile.gif
/ Smart Home Wiring #28
Bummer isn't it? Some of these indoor home projects really can cut into the seat time./w3tcompact/icons/sad.gif
/ Smart Home Wiring #29
Yes, SmurfTube indeed, I just didn't know if he knew that I knew that he knew if what I knew was what he knew and if he knew what I knew when we knew about using new smurf in a new house knowing what we now know, you know, Rat...
/ Smart Home Wiring #31
As far as boxes go, for more room use a 4x4 box and a plaster ring to make the opening 4x2. I ran 2 cable and 2 phone to each room when we remodeled. The idea was that if the bed and nightstand was on one side of the room then the TV would be on the other. And when the Lady decides to switch the room around I didn't have to hear her say, "can you move the Phone or Cable line". Also since all the phone lines terminated in the basement on 66 blocks I figured I could just unhook the kids phone lines to their rooms for punishment purposes. Then we got cordless phones. So much for that idea........
Then came the Cat5 stuff. I was glad I stubbed conduit out of each box into the basement.
What I would like to find is a good terminating box for the cable in the basement. Some kind of "apartment building" type bridge with a lot of connectors. Guess I will have to follow the Comcast truck around and hope one falls off.
And the #1 thing to remember " wire your family room for surround sound" I ran cable to all 4 sides of the room for 2 sets of speakers and bridged them together. No matter which wall she moves the TV, just plug back into the speaker jacks and the other 3 walls have live audio. Just plug each speaker into the jack for the channel you want...... Tom
/ Smart Home Wiring
I'm still kinda sore from it all but this weekend I pulled 1000 ft of RG6QS, 1000 ft of Cat5e and 750 ft of 14-2 speaker wire throughout our new house. I can't tell you how many times I went up and down various ladders /w3tcompact/icons/shocked.gif All went well and I thank everyone who provided advice. I did use the plaster rings for most of the locations. I'll do the basement later and I still need to wire some speakers in the garage (you'd think I would have done that first). I was thinking of doing the security system wiring but the wire type seems hardware dependant and I'm not ready for those decisions yet (mentally). Going to talk to the builder about having the security system put in by the pros.
Thanks again for the help everyone. I'll try to post a photo of my cable birdsnest tomorrow /w3tcompact/icons/smile.gif
/ Smart Home Wiring #33
Rob,
I believe security companies will wire your house at little or no charge if you sign a one year contract. You ought to check it out.
Bud
/ Smart Home Wiring
My thoughts exactly Bud, thanks for the tip /w3tcompact/icons/smile.gif
/ Smart Home Wiring
Here's a picture of the results of all my wiring efforts last weekend. Somehow, it looks more impressive in person. What isn't shown here is the speaker wires as I ran them to various entertainment center "zones" rather than a completely centralized system.
A quick tool review: Milwaukee "Hole Hawg" right angle drill is one kick a$$ piece of equipment. Good self-feeding bits are essential too /w3tcompact/icons/smile.gif
/ Smart Home Wiring
<font color=blue>He He!!! I used the same labels on my wiring </font color=blue>
Great minds think alike, eh David? Did you notice the highly sophisticated masking tape on some of the wires to differentiate dual runs to the same locations? Whatever works /w3tcompact/icons/smile.gif
/ Smart Home Wiring #38
That's where we differentiated; I used one band, two band, three band of electrical tape. (we were probably out of masking tape) /w3tcompact/icons/laugh.gif
/ Smart Home Wiring #39
Chuck,
Is there anything like a Cat 5 combined with Romex in the same sheathing? I swear I saw something like this at the NAHB show in Dallas a couple years back but haven't seen it anywhere since. I know historically there was concern about interference between Romex and Cat 5 but thought maybe it had been solved.
I'm wanting to build with SIP's and making single runs with something like that would be wonderful. Thanks in advance for any insights you can share.
/ Smart Home Wiring #40
Gary,
They made a hybrid cable for awhile that included all the 110 volt wiring with the cat 3 or 5 and a couple of coax cables.
Don't know if thats still being used anywhere or not.
2025 Swict 84in Bucket Skid Steer Attachment (A66734)
2025 Swict 84in...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
SOUTHERN FRAC MANIFOLD (A68842)
SOUTHERN FRAC...
2016 Ford F-650 18ft Hydraulic Dovetail Hauler Truck (A61573)
2016 Ford F-650...
2013 5x8 Port City S/A Enclosed Cargo Trailer (A66738)
2013 5x8 Port City...
2023 CRUISER RV SHADOW CRUISER (A67714)
2023 CRUISER RV...
