small trailer for b2620?
/ small trailer for b2620? #11
I have a very small utility trailer but could use a larger one for general use. I've been eyeing the 5x10 trailer with a 3500lb axle at TSC. Question is would my Kubota B2620 be okay on it for occasional trips like for service? roughly speaking the tractor/FEL/loaded tires weighs about 2400 lbs so it should be within the GVW.
I have a Load Trail 77" x 10' with the 3500 lb axle and it hauls my BX1850 with FEL & 54" MMM. I wouldn't want to haul it cross country but the 15 miles from the dealership was no problem. Not sure how TSC trailers compare to Load Trail.
Thanks everyone for your advice.
/ small trailer for b2620? #13
A well built 6'4" x 18' runs about $1800-$2000 if you can swing that, it will have brakes and be much more comfortable towing, that way you could haul your tractor with the FEL and any other attachments, trust me buy the right trailer now, we started out with a 5'x8 trailer and kicked ourselves in the butt every time we needed something larger (which seems to happen a lot with a small trailer!!!!!) now we own a 6' 4"x 18' and it made towing so much better!
/ small trailer for b2620? #14
Diamondpilot said:
Dont waste your money. Get a 16' car hauler or landscape trailer.
Another consideration on these small trailers if floor strength per sq ft. Your tractor has small tires and will put the load in 4 small spots. Ramps or gate will also be a problem with a 2,500# tractor.
Chris
It's always better to spend what is needed to get the job done than try to save a buck or two and wind up wasting the whole wad because what you bought won't properly do the job.
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
2025 AGT Industrial SDA-140W (A60463)
2025 AGT...
2013 MAGNUM PRODUCTS LIGHT TOWER (A60736)
2013 MAGNUM...
(INOP) MASSEY FERGUSON 543 TRACTOR (A59823)
(INOP) MASSEY...
2008 CAT D4K XL (A58214)
2008 CAT D4K XL...
Giyi XKH39 (A60463)
Giyi XKH39 (A60463)
