Buying Advice Small CUT or large SCUT Advice
/ Small CUT or large SCUT Advice
I'll be posting a review and photo thread when the tractor comes in.
/ Small CUT or large SCUT Advice #62
There's no way to rig any kind of position control for the J Series tractors. The 3pt lever works like an auxiliary hydraulic lever. There is no way to rig a stop that I can conceive. It really wasn't that big of a deal to me. I never used position control on my last tractor.
Ok. I'm back with photos of the G3033H position control. This is a manual position control with turn buttons. It mimics the old position control from the Farmall Cub, Super A, etc series of tractors.
First photo is of a G3033H with the manual position knobs. The knobs screw into some sort of threaded flat piece of metal that then locks in place.
Second photo is of J2023H's lift mechanism I think. From what I see, the same manual position knobs from the G3033H can be placed on the J20XXH's 3 point hitch setup and at least give you manual position control.
I checked with the dealer on this, and he said those parts are available. I didn't think to get the parts numbers for them.
Just thought it might help out some.
As of this past weekend, I'm probably going to opt for the G3033H myself. I can get it with TLB, tiller, remote hydraulics, rotary mower, and AG tires for $25408.00 out the door and delivered - tires loaded too.
J2023/J2030H same setup was about $21775.00 with same options. The J2030H is $100.00 more than the J2023H, so big deal on that. The price I posted here if for the J2030H.
My soil is clay soil and I have a pond to deal with. I'm thinking the 33 HP and extra clearance of the G3033H will suit my purposes better. I can only do this once, and I do not want buyers remorse.
I've heard and read it many times before: Select the tractor you think you will need and go one size larger. Hence my choice of a G3033H.
/ Small CUT or large SCUT Advice #63
J2023/J2030H same setup was about $21775.00 with same options. The J2030H is $100.00 more, so big deal on that.
I'm assuming the lift capacities and backhoe strength of the G3033 are quite a bit higher than the J ...?
/ Small CUT or large SCUT Advice #64
J2023H:
Main Specifications
Engine HP-23
PTO HP-17.5
Transmission- 2 range HST (Hydrostatic Drive Transmission)
3-Point Lift Capacity-1,433 lbs.
Loader Lift Capacity-1,270 lbs.
Hydraulic System
Implement pump, gpm: 6.4
Steering pump, gpm: 2.8
Total flow gpm: 9.2
Category, 3 pt hitch: CAT 1
Hitch Lift capacity, lb: 1433
Lift control type: Manual Position
Quick Attach Front End Loader with Grill Guard & 50 Bucket LL2101
Maximum Lift Height, in. 85.7
Clearance with Attachment Dump, in. 65
Reach at Maximum Height, in. 22
Maximum Dump Angle, deg. 52
Maximum Rollback Angle, deg. 43
Digging Depth, in. 4.4
Overall Height in Carry Position, in. 42.8
Lift Capacity (@ Pivot Pin), lbs. 1270
Breakout Force (@ Pivot pin), lbs. 1640
Approx. Weight (Loader w/o Bucket), lbs. 638
6 Quick Attach Backhoe with available 9? 12 & 16 Bucket - LB1104
Digging Depth, in 79.3
Reach From centerline of swing Pivot, in. 113.3
Loading Height, in. 56.9
Swing Arc, deg. 150
Transport Height, in. 75.3
Bucket Rotation, deg. 163
Stabilizer Spread (Down Position), in. 86.8
Stabilizer Spread (Up Position), in. 55.7
Bucket Digging force, lbs. 2096
G3033H:
Main Specifications
Engine HP - 33
PTO HP - 26
Transmission - 3-Range Hydrostatic Drive (HST)
3-Point Lift Capacity - 1,808 lbs.
Loader Lift Capacity - 1,600 lbs.
Hydraulic System
Implement pump, gpm: 7.4
Steering pump, gpm: 4.5
Total flow gpm: 11.9
Hitch Lift capacity, lb: 1808
Quick Attach, Skid Steer Compatible Front End Loader with Grill Guard & 66" Bucket LL3102
Maximum Lift Height, inches: 90.7
Clearance with Attachment Dump, inches: 59.8
Reach at Maximum Height, inches: 20.4
Maximum Dump Angle, deg. 48
Maximum Rollback Angle, deg. 38
Digging Depth, inches: 6.7
Overall Height in Carry Position, inches: 48.5
Lift Capacity (@ Pivot Pin), lbs. 1600
Breakout Force (@ Pivot pin), lbs. 2628
Approx. Weight (Loader w/o Bucket), lbs. 1124
6' Quick Attach Backhoe with Available 9", 12", 16" and 18" Bucket - LB1102
Digging Depth, inches: 76.3
Reach From centerline of swing Pivot, inches: 113.1
Loading Height, inches: 63.6
Swing Arc, deg. 180
Transport Height, inches: 77.2
Bucket Rotation, deg. 180
Stabilizer Spread (Down Position), inches: 68.7
Stabilizer Spread (Up Position), inches: 46.4
Bucket Digging force, lbs. 2817
I hope this will display correctly. This is from the LStractorUSA.com website.
/ Small CUT or large SCUT Advice #65
Oh, yeah. I'm not a dealer. I'm just looking for a new tractor to replace my 64 year old Farmall Cub. Time to get into the 21st Century. :):thumbsup:
The J2023 will be a smaller frame, but it seems a little nicer featured compared to the G Series. The G Series is what they call their "value compact" model. Just a little cheaper looking on the details. The G is a much heavier tractor.
Price on the J2023 seems high. I just ordered a brand new one for $12,200 with a loader. I was quoted a little over $5k for the LS backhoe installed with the auxiliary remote. So call it $17,500 in a TLB configuration. If it were me, I'd save some money and try to find lightly used attachments locally on Craigslist.
/ Small CUT or large SCUT Advice #67
Don't get me wrong. I like the J2023 a whole lot. But, with the pond area, and having to go behind the pond dam, I really think I need the extra clearance underneath. Plus, I will be pulling a plow from time to time for planting corn, etc. Again, clearance underneath becomes a bigger issue.
The price on the J2023H included the TLB, remote hydraulics, tiller, and rotary mower too. All sized to the tractor. I can't find a better deal where I live for that kind of money. Same goes for the G3033H.
Just a Kubota B series with the FEL in my area is $15,800 + tax and prep. And, it has that blasted treadle pedal setup that I definitely do not like.
If you're doing ground engaging tasks, the G3033 would probably be the better choice then.
/ Small CUT or large SCUT Advice #69
I don't think changing the knobs will make any difference in how the 3pt works on the J. With the manual style, when you push forward the 3pt goes down. How far forward you push only changes the rate at which it drops, not where it will stop. If you only push the lever forward a little bit, the 3pt will still eventually bottom out. You have to center the lever to stop the 3pt from further movement. The same is true for raising the 3pt, and pulling the lever back.
If the G3038 isn't much more expensive, it's worth considering, because the FEL has 300lbs more lift capacity.
It was a little more than $3000 higher for the G3033H from my dealer.
/ Small CUT or large SCUT Advice #71
Don't forget that a tiller and mower deck probably add $5K.
/ Small CUT or large SCUT Advice #72
I was actually talking about the price difference between the 3033 and 3038. The 3038 has 300lbs more FEL lift capacity, which can make a big difference....it's almost 20% extra :)
I gotcha. Wouldn't think there would be much price difference between those two models then.
That's why I recommended looking for used. 5ft tillers in my area sell new for $1500-$1600. I would say the OP could easily by a new brush hog and new tiller for about $2500. Used would be even cheaper.
I went down to see my family this weekend and I was telling my dad about the new LS tractor that I ordered and how excited I was to start playing with it. He got this big smile and said he got a new tractor too and wanted to know if I wanted to play with it for a while. He took me around to the back of the shop. This is what I saw and my jaw hit the floor. He's such a one-upper. :)
/ Small CUT or large SCUT Advice #76
:eek:
