slip on 4 way wedge
/ slip on 4 way wedge #1
sizzami
vt
kioti dk 45
here is the wedge design I use on my splitters this one is for a true 20 ton machine the scale gets larger with the size of machine.
/ slip on 4 way wedge #2
Nice job, I like the little winglets :p
/ slip on 4 way wedge #5
I like it alot......Been thinkin' of something like that years! Like the E-Z on, E-Z off aspect! Thanks for sharing! ~Scotty
/ slip on 4 way wedge #7
Yup, gave me an idea to, I think I can do that.
Anything that save a step or two helps.
/ slip on 4 way wedge #8
Sizzami:
Nice work, very nice work. Question for you. It appears the business end of the wedge is a different material, what did you use? Also, what equipment did you use to bend the ends of those plate sections toward the front of the wedge?
Thanks for sharing with us. Appears as though you have stirred some creative juices.
/ slip on 4 way wedge #9
Sizzami;
Very nice work. I too would like to know what materials you are using and what are you using to make those great looking welds. Good job.
SimS
the single wedge is , 1/4 plate . the slip on is 3/8 plate the joint at the front is a piece of 1/2 plate , beveled and welded then sanded down.
I did the bends in a press brake.
I use a lincon cv-300 w/.030 wire.
/ slip on 4 way wedge #11
Nice looking wedge! I'm building a new splitter now, do you think that wedge would work with a lift on it also? Sort of like what the rayco or timberwolf does?
Wayne
20 tons is very adequate, the guys in maine or oregon may disagree, but ,usually we dont see giant trees here in vt anymore.
2004 Mack CV713 Granite Fuel and Lube Truck (A59230)
2004 Mack CV713...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
2013 Haulotte 4527A (A57148)
2013 Haulotte...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
