slip on 4 way wedge
   / slip on 4 way wedge #1
sizzami
vt
kioti dk 45
here is the wedge design I use on my splitters this one is for a true 20 ton machine the scale gets larger with the size of machine.
   / slip on 4 way wedge #2
Nice job, I like the little winglets :p
   / slip on 4 way wedge #5
I like it alot......Been thinkin' of something like that years! Like the E-Z on, E-Z off aspect! Thanks for sharing! ~Scotty
   / slip on 4 way wedge #6
How does the 20 ton handel it? Thanks
   / slip on 4 way wedge #7
Yup, gave me an idea to, I think I can do that.
Anything that save a step or two helps.
   / slip on 4 way wedge #8
Sizzami:
Nice work, very nice work. Question for you. It appears the business end of the wedge is a different material, what did you use? Also, what equipment did you use to bend the ends of those plate sections toward the front of the wedge?
Thanks for sharing with us. Appears as though you have stirred some creative juices.
   / slip on 4 way wedge #9
Sizzami;
Very nice work. I too would like to know what materials you are using and what are you using to make those great looking welds. Good job.
SimS
the single wedge is , 1/4 plate . the slip on is 3/8 plate the joint at the front is a piece of 1/2 plate , beveled and welded then sanded down.
I did the bends in a press brake.
I use a lincon cv-300 w/.030 wire.
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
1990 Nitro Bass Boat with S/A Galvanized Trailer (A51694)
1990 Nitro Bass...
2024 Big Tex 14GN-40D5A 35ft Gooseneck Flatbed Trailer (A51691)
2024 Big Tex...
8ft Fork Extensions (A51691)
8ft Fork...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A53473)
GOODYEAR SET OF...
