slip on 4 way wedge
   / slip on 4 way wedge #1
sizzami
vt
kioti dk 45
here is the wedge design I use on my splitters this one is for a true 20 ton machine the scale gets larger with the size of machine.
   / slip on 4 way wedge #2
Nice job, I like the little winglets :p
   / slip on 4 way wedge #5
I like it alot......Been thinkin' of something like that years! Like the E-Z on, E-Z off aspect! Thanks for sharing! ~Scotty
   / slip on 4 way wedge #6
How does the 20 ton handel it? Thanks
   / slip on 4 way wedge #7
Yup, gave me an idea to, I think I can do that.
Anything that save a step or two helps.
   / slip on 4 way wedge #8
Sizzami:
Nice work, very nice work. Question for you. It appears the business end of the wedge is a different material, what did you use? Also, what equipment did you use to bend the ends of those plate sections toward the front of the wedge?
Thanks for sharing with us. Appears as though you have stirred some creative juices.
   / slip on 4 way wedge #9
Sizzami;
Very nice work. I too would like to know what materials you are using and what are you using to make those great looking welds. Good job.
SimS
the single wedge is , 1/4 plate . the slip on is 3/8 plate the joint at the front is a piece of 1/2 plate , beveled and welded then sanded down.
I did the bends in a press brake.
I use a lincon cv-300 w/.030 wire.
2004 INTERNATIONAL 4300 BOX TRUCK (A53426)
2004 INTERNATIONAL...
2011 Kubota ZG222 (A50123)
2011 Kubota ZG222...
CFG Industrial SAII100 (A50123)
CFG Industrial...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A51692)
2023 Fat Truck...
2015 JCB 525-60T4 5,500lb 4x4 Rough Terrain Telehandler (A51691)
2015 JCB 525-60T4...
