Gordon Gould
Super Member
- Joined
- Apr 1, 2007
- Messages
- 6,768
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
I don't believe any of the winches (at least Farmi's) are QH compatible. I found with my QH and JL501T that the top link is too high to use. After seeing how the winch works I believe I know why this is. Instead of having the top link arm and lower arms parallel, which lifts an implement straight up, the arms are not parallel. Non-parallel arms will kick the bottom of the winch outward when lifting, this creates a "shelf" and helps support the butt of the logs being hauled. It is quite ingenious and works very well (at least on my tractor).
Blane
(also from NW Oregon)
Blane thank you for answering OregonCraigs question for me. Somehow I missed it. I apologize Craig.
I don't know QH stuff but my small JL290 winch also has a high top link connection point like Blane described. Not only does it give the shelf effect it gives you more lift by rolling up like that.
gg
