Simple solar panel tracking system
/ Simple solar panel tracking system #21
I'm not sure if this is the right place to post this project - maybe it should be over at the Rural Living Forum since it doesn't involve tractors? My apologies if that's the case, but it is definitely in the build-it-yourself project category.
I have two water wells on my property with 24 volt DC submersible pumps powered by
solar kits. The pumps are hooked up PV direct; in other words there are no batteries in the circuit, the panels power the pumps directly. Since the pumps only run when there is sun on the panels, to maximize well output I need to maximize the hours of sun exposure. Having the panels rotate throughout the day to track the sun's movement does that. Since my wells are low gallons per hour, being able to pump for more hours per day can increase production by 40% in the summer. Commercial PV panel tracking systems are available but quite expensive, so I came up with a simple low tech method that has worked perfectly over the years. PV direct water pumping really benefits from tracking, especially in the summer when you typically need more water and the sun moves across the sky in a bigger arc. But any small solar panel installation would benefit from the same system. I also use pump controllers with linear current boosters, which dramatically increase pump speed during low light conditions.
My system uses the weight of water in a 5 gal. bucket to rotate the PV panel four times a day. The PV panel mounts with two pivot bolts to a triangular frame so it can rotate through 90 degrees. Springs pull the panel toward the east, while the bucket pulls a rope to rotate the panel toward the west. A battery powered irrigation timer is set to add water to the bucket four times per day. Each time it does, the bucket pulls harder against the panel, rotating it to a new position. At the end of the day a separate timer drains the bucket, and the springs rotate the panel back facing east again for the next morning. The PV frame mounts to a tower with adjustable struts so I can manually adjust the north/south tilt flatter in summer and angled more southerly in winter.
Calibrating the timer and springs was simple. I just went out at around 10:30 a.m., manually turned on the fill timer, and noted how long it needed to run to rotate the panel the right amount. I repeated this at 12:30 p.m., 1:30, and 3:30 and programed the timer accordingly. I used three springs that engage successively to apply more resistance as the panel rotates. The springs and bucket connect to the panel with ropes, guided by small pulleys. Half of an old bicycle rim attached to the panel works like a big pulley so the ropes pull on the panel at a constant radius. The panels track consistently, even on windy days. I imagine another method would be to use a linear actuator or gate opener powered by a sprinkler timer (the type that turns sprinkler valves on and off). In my case since I am pumping water I had water supplies near each well. Since solar systems are so expensive, it really makes sense to maximize system performance with tracking.
Awesome man thanks for sharing out the details of the system..With plenty of sunshine I can surely use the system to increase the output.
Well system will work I have asked my expert friend so really thanks..
/ Simple solar panel tracking system #22
Kays, yes that freon system is still around and works just as you described. Expensive though, and I'm cheap and like to build things, hence my water powered system.
Propane would work just like the Freon does, and being under $5 a gallon that is reasonable in cost.
it has the same pressures properties as R22, but more efficient when used as a refrigerant,
most of the hydrocarbon refrigerants, are propane or a mixture of propane and butane or ethane, depending on the pressures they are wanting to obtain,
/ Simple solar panel tracking system #23
As the suns position at any given time relative to any given location can be found in a navigation table could you not have the panels moved by DC motor controlled by a timer hooked to a calculator, computer or cell phone with the necessary data in it's memory? No need to see the sun cloudy or not.
2007 30ft. Regal 30 Express Cruiser Boat with 2010 Vantage T/A 33 Ft. Trailer (A64557)
2007 30ft. Regal...
2012 HINO 268 4X2 S/A BOX TRUCK (A59914)
2012 HINO 268 4X2...
2024 KOMATSU PC88MR-11 EXCAVATOR (A65053)
2024 KOMATSU...
2012 FREIGHTLINER CASCADIA 125 6X4 T/ANDEM  SLEEPER TRUCK TRACTOR (A67147)
2012 FREIGHTLINER...
2022 CATERPILLAR D1 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
More info coming soon (A61574)
More info coming...
