Simple solar panel tracking system
/ Simple solar panel tracking system #1
spurlocktool
N. California
Kubota BX1500, BX2230
I'm not sure if this is the right place to post this project - maybe it should be over at the Rural Living Forum since it doesn't involve tractors? My apologies if that's the case, but it is definitely in the build-it-yourself project category.
I have two water wells on my property with 24 volt DC submersible pumps powered by photovoltaic (solar) panels. The pumps are hooked up PV direct; in other words there are no batteries in the circuit, the panels power the pumps directly. Since the pumps only run when there is sun on the panels, to maximize well output I need to maximize the hours of sun exposure. Having the panels rotate throughout the day to track the sun's movement does that. Since my wells are low gallons per hour, being able to pump for more hours per day can increase production by 40% in the summer. Commercial PV panel tracking systems are available but quite expensive, so I came up with a simple low tech method that has worked perfectly over the years. PV direct water pumping really benefits from tracking, especially in the summer when you typically need more water and the sun moves across the sky in a bigger arc. But any small solar panel installation would benefit from the same system. I also use pump controllers with linear current boosters, which dramatically increase pump speed during low light conditions.
My system uses the weight of water in a 5 gal. bucket to rotate the PV panel four times a day. The PV panel mounts with two pivot bolts to a triangular frame so it can rotate through 90 degrees. Springs pull the panel toward the east, while the bucket pulls a rope to rotate the panel toward the west. A battery powered irrigation timer is set to add water to the bucket four times per day. Each time it does, the bucket pulls harder against the panel, rotating it to a new position. At the end of the day a separate timer drains the bucket, and the springs rotate the panel back facing east again for the next morning. The PV frame mounts to a tower with adjustable struts so I can manually adjust the north/south tilt flatter in summer and angled more southerly in winter.
Calibrating the timer and springs was simple. I just went out at around 10:30 a.m., manually turned on the fill timer, and noted how long it needed to run to rotate the panel the right amount. I repeated this at 12:30 p.m., 1:30, and 3:30 and programed the timer accordingly. I used three springs that engage successively to apply more resistance as the panel rotates. The springs and bucket connect to the panel with ropes, guided by small pulleys. Half of an old bicycle rim attached to the panel works like a big pulley so the ropes pull on the panel at a constant radius. The panels track consistently, even on windy days. I imagine another method would be to use a linear actuator or gate opener powered by a sprinkler timer (the type that turns sprinkler valves on and off). In my case since I am pumping water I had water supplies near each well. Since solar systems are so expensive, it really makes sense to maximize system performance with tracking.
/ Simple solar panel tracking system #2
Very ingenious.
/ Simple solar panel tracking system #3
spur,
That's ingenious and fun to make, etc. But what percentage of the PV panels output is used to operate the setup? If you barely had the power to run the well and needed tracking to actually run the well, would it have made more sense to just run two panels with no tracking and had all the power go to the well?
Tracking is a way to increase collector effectiveness, but I find all the fiddling around, extra machinery and power used to run the tracking system seems like a net loss compared to the lower, off peak efficiency, but higher peak output of a larger, non tracking system with the same overall initial cost.
What's your take on it?
/ Simple solar panel tracking system #4
Pretty ingenious
/ Simple solar panel tracking system #5
Raspy,
Thanks for your reply. My tracking system works by water pressure, not electricity, so there is no extra use of power from the panels. The well storage tank is on a hill, so the water pressure is from gravity. Only about 4 gallons of water needs to be pumped each day to operate the tracker, which is insignificant when I'm pumping up to 1000 gallons per day.
If I had a high producing well it would be possible to use a faster pump/higher wattage PV array without tracking to get the same amount of water per day as I currently produce with a lower power system with tracking. But all of my wells are low producing. They have to be pumped very slowly since they refill slowly, so more hours of pumping is the only way to maximize output.
Kays, yes that freon system is still around and works just as you described. Expensive though, and I'm cheap and like to build things, hence my water powered system.
/ Simple solar panel tracking system #8
Spur, Very clever & simple. I've some panels to mount when I retire next year & was thinking of a tracking system using photocells in tubes running timers/motor. Not sure your system would work for me at -40F. How much efficiency do you think you get vs static mounted panels?
I've also seen panels with mirrors on each side to intesify light which also need to be "aimed". MikeD74T
Mike, when I've compared total amount of water pumped with my panels fixed versus tracking, there is at least a 40% increase during summer, much less during winter since the sun doesn't move in such a large arc across the sky.
For water pumping and similar uses, a linear current booster is another big performance booster. During periods of low light (early morning, late afternoon, any time a cloud comes over), these solid state controllers trade off extra voltage for increased current, giving the pump motor enough torque to start and run at least slowly instead of stalling. So the combination of an LCB and tracking makes a huge difference in useful work done by the PV panels.
/ Simple solar panel tracking system #10
I haven't tried it on solar panels but on a solar heater a sheet of white styrofoam (or any white material) placed horizontally at the bottom of the panel increases the temperature within the panel 25°F in short order.
/ Simple solar panel tracking system #11
40% is a huge increase. At latitude 44.5 degrees I also have a large summer arc to deal with/take advantage of. MikeD74T
/ Simple solar panel tracking system #12
What system is in place to prevent it from just getting rocked around during a storm?
The system is quite clever, and I am impressed, but I would be worried that heavy winds would have this thing beating itself until it broke.
/ Simple solar panel tracking system #13
I love it when technology meets simplicity. Great job, wonderful photos.:thumbsup:
At first I was concerned that might be a problem, but wind has no effect and being in the hills we get plenty of strong gusty wind. The panel pivots on it's center, so wind pressure is equal on right and left sides of the panel. Plus there is a certain amount of friction in the pivot bolts and washers due to the weight of the panels. There is also a bit of friction in the pulleys that guide the ropes, so any tendency to move from swirling winds is dampened. My first tracking system has been in use for twelve years, and the second for 6 years with no problems on either.
/ Simple solar panel tracking system #15
I haven't tried it on solar panels but on a solar heater a sheet of white styrofoam (or any white material) placed horizontally at the bottom of the panel increases the temperature within the panel 25ーF in short order.
You don't want to do this with Photvoltaic systems. Heat is an enemy to electric production as it reduces the efficiency of the panels. Heat is the goal for a solar heater, but not for a pv panel.
I saw a show on Discovery a while back where someone was producing a combination panel that used a solar heating panel to capture the heat and cool the PV panel. Think of it as a radiator attached to the photovoltaic panel using the pv panel as it's engine.
/ Simple solar panel tracking system #16
I didn't read the whole article. What is the expensive part of the freon system?
Commercial trackers are sold as a complete mechanism to install on either a mast or ground mounted. Prices depend upon how big a solar array they can hold. For instance, Zomeworks makes freon passive trackers in six sizes to fit 20 sq. ft. of panels @$700 on up to their largest (168 sq/. ft.) at $4,200.00
My water-weight tracker only has to handle 9 sq. ft. of panel.
/ Simple solar panel tracking system #18
I finished the article. $39 total cost. Seems cheap enough to me.
/ Simple solar panel tracking system #19
Awesome man thanks for sharing out the details of the system..With plenty of sunshine I can surely use the system to increase the output..
/ Simple solar panel tracking system #20
Spurlocktool...I wonder if you could convert your bucket to an autosiphoning system (ie, when it reaches a certain level it automatically siphons itself dry and resets to the east via the springs)? Then, you could eliminate one set of timers; you'd only need to get the fill rate right to have the bucket fill and empty on schedule. I love seeing these home-made engineering solutions!
Bob
1995 T800 TRI/A DUMP TRUCK TRACTOR (A67148)
1995 T800 TRI/A...
1987 Fruehauf MC 307 Insulated 7,500 Gallon T/A Chemical Tanker Trailer (A64194)
1987 Fruehauf MC...
2006 Western Star 4900 Concrete Mixer U98358 (A62613)
2006 Western Star...
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
2021 DITCH WITCH HX30 TOWABLE VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
