Shrub Bucket
/ Shrub Bucket #11
Very nice. Let me know how it works on transplanting little spruce.
Bob
/ Shrub Bucket #12
Hey, nice job! I want one. I saw one on the front of a Bobcat at the local county fair this fall. Surprizingly it was very well sharpened on the leading edge. Did you consider grinding an edge onto it? Might be easier to get it into the ground, and cut thru some smaller roots that way.
Anyway, looks great! /forums/images/graemlins/grin.gif
/ Shrub Bucket #13
Brad that is a nice looking project. Very professional looking! I hope that it works well for you also when you put it to work.
/ Shrub Bucket
Yup, I already did grind the edge. It isn't razor sharp, but I think I will sharpen it even better than it is. It does make a difference cutting through roots.
/ Shrub Bucket #15
That is a terrific idea and a nice implementation. You've posted a bunch of projects and they all look really great. Thanks for letting us see them.
Cliff
/ Shrub Bucket #16
</font><font color="blue" class="small">( I've been thinking of making something similar for my skid steer.)</font>
I believe Gatorboy has a similar product that he uses on his Bobcat skid steer.
/ Shrub Bucket #17
Next time you make top brackets, get a hunk of pipe with an inner diameter just bigger than the OD of the top of the quick tach bracket. Cut it lengthwise so you have a little over half of the pipe circumference. Weld that to your frame, then take barstock and weld to the frame, heat and bend over the pipe and weld to the pipe. See attached. Works every time.
/ Shrub Bucket
Thanks, good tip. I did actually plan to do something like that originally, but you know how it goes - it's the weekend, the metal store is closed, you are on a roll, and it is so close to going on the tractor ..... I just couldn't wait so did it this way. It definitely wasn't the easiest thing to get it to fit even this good, so next time it is the 1/2 pipe thing and actually mount it to the loader with clamps or something so everything can be tacked in exactly the right place.
/ Shrub Bucket #19
Great job and very good idea.
Has anyone thought of making one of these for the 3 point hitch ? It seems like it would work very well with a top tilt cylinder on it.
/ Shrub Bucket #20
</font><font color="blue" class="small">( get a hunk of pipe with an inner diameter just bigger than the OD)</font>
I know this is out of context, but this is how I read it. I'd like to find a piece of pipe like that.
Cliff
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A61307)
2021 Takeuchi...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52709)
2007 CATERPILLAR...
2017 Ram 5500 Bucket Truck (A61307)
2017 Ram 5500...
Giyi GY-CWG72 Quick Attach Curved Wood Grabber (A60463)
Giyi GY-CWG72...
AGT Industrial ATK-B1000 2 Post Car Lift (A60463)
AGT Industrial...
