Hinge for folding bale tines
/ Hinge for folding bale tines #1
madtowneast
Massey Ferguson 4707
I am trying to design some bale forks with folding bale tines. I got as far as the general structure.
I am somewhat stuck on the details. The square tube are sized according to other bale forks I checked out (3x4x1/4, 2x4x1/8). The plate used is 3/4" right now, which may be overkill, but they are meant to handle up to 3000 pounds.
The big thing I am stuck on is how to design the hinges. Looking at other examples of bale tines with moving tine bar, the pins they use vary between 1/2 - 1-1/2". I was thinking about using some off the shelf 25 mm excavator bucket pins, but they are usually housed with bearings, etc. which seems overkill to other examples I have found: Example 1, Example 2, Example 3, Example 4
Anybody have inside into how to design the hings?
/ Hinge for folding bale tines #2
1) You haven't defined the bale size or weights expected.
2) Why folding ? Can't you just do a QA tine rack and pick up or drop off as needed ?
3) If you insist on fold down tines, use a locked down type hinge that you release with a pin? When in bale holding position let the spikes be sitting on the stops.
4) Whats the weight carrying capacity of your loader or 3 point hitch ? This looks very heavy for just a round or large square bale.
5) Were you thinking hydraulic deployment ? Individual spikes aren't that heavy.
6) How many bales do you want to carry at 1 time ?
Up to 3000 pounds, with 2 large square bales of alfalfa.
When stacking over 3 high in my barn, pulling out the tines gets dicey. They tend to "stick" to the bales and want to pull the entire stack down. With the hinge you can "push off" without needing hydraulics.
I designed stops into the back, so the tines can only tilt towards the upper portion. And some 1/2 holes for a pin if needed
2x large square bales of alfalfa, so about 1200-1300# each.
No
2-3 depending the size and type.
/ Hinge for folding bale tines #4
What do you think of some sort of 'push-off feet' ? My stack wagons have various versions of 2 plates that extract the machinery. Could be dangerous, though: max height and you on the brakes.
True, I found a few manufacturers that make a bale spear with a hydraulic push off bar. My concern with that is how to coordinate driving back and pushing things bales off the tines at the same time.
Retracting tines or hooks are a better option. And I have found those as well but those are really expensive.
/ Hinge for folding bale tines #6
These are stronger than the hinges on my FEL's with spikes, will likely out last them too and they are simple.
What hinge you might want depends on the rest of the design.
/ Hinge for folding bale tines #7
There’s a company in Lancaster County, PA that already makes a similar set up
The spears are rigid when pushing into the bale, but when you back out, they move vertically a little, to ease the sticking problem.
I have the same issue, but even with 100% rigid forks I have, I came up with 2 methods of helping them release.
1. I stack my 4x4x8’s four layers high (16’). I bring the bales in from the field to the stacking spot (2) bales at a time. The first 2 are easy since they are on ground level. I would then bring in the 3rd bale, place it on top, then bring in the 4th bale and finish the stack. That was the hardest one to stack since it had the tendency to pull the whole stack over towards the tractor when withdrawing from the bale. Many years ago, I discovered it is much easier to bring 2 bales in, and stack them on top of the lower (2) bales. That way the spears are in the 3rd bale from the top, not the 4th bale. This lowers the spears’ center of gravity and adds the weight of a 4th bale on top. Makes it real easy to withdrawal.
2. In the event I do still encounter resistance withdrawing from the bale, I “wiggle” the loader curl function up and down with the spears fully immersed in the bale. This creates “slots” in the bale and the spears pull out easily.
/ Hinge for folding bale tines #8
I’ve wanted to try one of these, but I don’t really need it anymore with the steps I use now.
I bet if you put one bale on the floor, then stack the next 2 together on top of the single, you’ll find it’ll withdrawal much easier with the added weight of the 3rd bale on top.
Those look like just flanged bronze bushings. Or are they something else?
I have found that company as well. I contacted them about a video to see how much theirs move and haven’t heard back in over a week. Honestly, it seemed like a recipe for something to wear out quickly or get stuck in a weird way.
I usually do 5 3x3x8s and do put the last 2 ontop of the bottom 3. I still have a lot of issues. I also tried putting another stack of 3 in front as stop to keep the stack from moving the same issue.
I will need to try that.
/ Hinge for folding bale tines #11
3x3’s are nasty to stack.
/ Hinge for folding bale tines #13
Maybe the first row. Once youve got a stack you dont habe to drive back, only help a little while pushing yourself back
/ Hinge for folding bale tines #14
When carrying two at a time, i push the loader down and roll the fork back. This prevents me from pulling the stack over whilst retracting. Which is an issue in maybe 2 out of 10 bales so i never bothered a fancy solution.
Forage traders and contractors have Meijer bale grabs with two prongs at the bottom, and hydraulic hooks above that grab the upper bales, so you can speed over the stubble towards the truck and load each spot to legal height in one movement.
I have tried having the loader push down on the stack. It works until you get up to like 4. After that it always is an issue with pulling the stack down.
Yeah I have seen a lot of different variants from European manufacturers. If the importing for one thing wasn't so expensive I would just buy it there.
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
(2) UNUSED 15-19.5 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 15-19.5...
2014 Screen USA TROM 6090 Trommel Screener (A61572)
2014 Screen USA...
2016 INTERNATIONAL PROSTAR+ 122 6X4 ROAD TRACTOR (A64280)
2016 INTERNATIONAL...
Kivel Quick Hitch Skid Steer Attachment (A61572)
Kivel Quick Hitch...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
