Backhoe Ripper
/ Backhoe Ripper
I am interested in building a similar attachment for my L48 with BT1100 backhoe, and have a few questions about your build. It is obvious to me that your metal fabrication skills and experience are far more advanced than mine. Your finished product looks great.
1. I am planning on laminating my tooth also. I bought 3 pieces of 1/4" plate, but I am having second thoughts about if a total of 3/4" of tooth thickness is appropriate for the power rating of my machine.Since I am just a stupid retired carpenter and not an engineer, I would like to have a better feel for if 4 layers of plate might be warranted or not for my machine. Can you provide power rating details on your machine for me to compare with my L48?
2. As I noted earlier, my skills are not nearly as advanced as yours are, so I would like to absorb some of your experience before I totally screw mine up. Can you describe the general welding processes you used?
I would really like my project to look as professionally fabricated as yours, though I am sure that it will not. I mainly just want it to be stout enough for my needs.
Thank you very much for posting your build,
Doug
My backhoe actually has slightly higher bucket and crowd arm forces then the L48, I assume you are using regular A36 hot rolled plate?
The steel I used for the shank was Hardox 450 which is a bit stronger than A36, so I can't comment first hand on the strength of a ripper made with A36.
It should be fine with A36, but will be slightly weaker and have less abrasive resistance.
For welding, I used a dual sheilded wire, it has a 70ksi strength, an equivalent stick rod would be a 7018.
Sent from my SM-S921U using TractorByNet mobile app
/ Backhoe Ripper #52
Another pic. This ash tree had 3-4 large side roots and massive tape root. This was before the KX 80 was part of the toys to play with so the M59 wrestled with this one for 4 hours. Had to completely undermine this stump before it could be broken free. I could have parked a volkswagon beetle in that hole.
I suggest you add a replaceable tooth to the ripper since some soils are extremely abrasive. My NC property has a rock layer about 2-4 feet under the surface that is really tough on leading edges.
M59, a replaceable tooth is part of the plan.
/ Backhoe Ripper #53
TMGT,
My local supplier had AR400 grade available, so I went with it for the laminated shank. Everything about this project will be a learning experience for me. So any information I can absorb is very much appreciated.
In my research, I have learned that preheating would be adviseable. Especially on the quick connect ear/base plate joints, and the shank/base plate joint. Somewhere in the 200+ degree range. So I am planning on including preheat as part of the process for those joints.
The machines available to me are a Primeweld 180 amp capable MIG/flux core/stick or my old Lincoln AC225 Tombstone. My brother in law has a much more capable MIG machine than either of those two, so it could be available if needed. Though I would prefer to just use my machine at home.
This build will be much more of a hobbyist, DIY project than yours and other's builds, so I appreciate your reply and further input you or others may have.
Many thanks again,
Doug
/ Backhoe Ripper #54
Thank you, that means a lot coming from someone of your fab skills!
They really allow a smaller backhoe do bigger work quicker when it comes to stumps, and less ground disturbance.
This is a 28" red oak I just took down, took maybe 1hr to get it down. Root ball had about 2yrds of soil attached to it! Had to use the ripper to knock enough of the dirt off just so I could roll the stump oit of the hole.View attachment 4239590View attachment 4239591View attachment 4239592
Sounds really familiar. I couldn't lift this one out of the hole because of the rootball dirt either. We had big rains and now it froze. I walked down into the hole today. Right at six feet at the deepest point, now that the rain got rid of much of the root ball dirt Should be able to get it out of the hole. at the cut this was maybe 30 inches diameter.
I really like the ripper you fabbed and definitely going to build one for the 550. I am going to check out what some hardox sells for locally and also AR 400 but sure both will be a shock.
/ Backhoe Ripper
I wish the rain could clear dirt off my rootballs, the clay under that red oak was practically concrete.
Ar400 will probably be easier to find from a metal supplier as there are more manufacturers.
Hardox is a brand name from SSAB, if you have any shops that repair or manufacturer excavation equipment they might have some drops or buy a chunk off a plate.
My buddies shop re-lines/floors trash truck bodies, so I have a bunch of odd shaped (usually skinny, long, and tapered) drop pieces laying around here.
The typical sheet he buys is 8'x20'.
I prefer working with Hardox over AR, Hardox seems more consistent and is less brittle then AR when forming.
/ Backhoe Ripper #56
We do have a few large heavy equipment repair and metal fab shops plus a metal seller/recycler locally.
Going to keep my eyes and ears open for some drops if possible.
I plan to get the plasma table assembled first and make the ripper one of the early projects.
Beautiful work all the way around on that ripper. Thanks again.
MULCHER (A58214)
MULCHER (A58214)
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
2022 Ford Explorer AWD SUV (A59231)
2022 Ford Explorer...
2015 Chrysler 200 Sedan (A59231)
2015 Chrysler 200...
Pat's QH and hydraulic top-link.
Pat's QH and...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
