Should I worry???
/ Should I worry??? #1
Jordan9682
Southwest sk
New holland 9682
image.jpgI'm thinking of buying this disc, its 33" wide and the discs aren't at a very aggressive angle. Should I worry about killing my quad? (Burning off the belt, ENGINE OVERHEATING, etc)
How heavy does this disc pull compared to a harrow? (How big of spike tooth harrow pulls about the same as the disc?)
Or will I loose traction way before then?:confused:
/ Should I worry???
Have no tractors under 100 horse
Useless how? Just don't go down?
As far as not going down, I can find a way to add weight to it
/ Should I worry??? #4
Looks like the king cutter I have. For breaking ground it's useless even with weight added. I pulled it with my Polaris 800 and it handed it well. Transmission got very hot but I never over heated or burned out a belt. Yes it wore the belt a lot faster and was **** on nearly every part of the atv driveline. It did over heat a friends Mule 610 (400cc).
The only way I could get it to cut was to rearrange the discs and do circles.
After a couple years of struggling I gave up on the disc and using an atv for a y serious work and bought a CUT last year. I'd be happy to sell you my atv disc so I can afford a real 3pt disc.
/ Should I worry???
Got one last week. I have 140lbs of weight on and im quite happy with it(im in sand so that probably makes it alot easier going down) will break up grass after a few passes. My quad pulls it quite easy, easier than i thought it would!
213089 (A64276)
213089 (A64276)
2018 Ford Fusion Hybrid Sedan (A64557)
2018 Ford Fusion...
Salt Dog by Buyers Slide in Spreader Box 10' (A62679)
Salt Dog by Buyers...
2000 LUFKIN FL-II T/A  48FT FLATBED TRAILER (A59914)
2000 LUFKIN FL-II...
2005 Dynapac CT262 Sheep's Foot Compactor (A62679)
2005 Dynapac CT262...
New/Unused Wolverine Quick Attach 72in Grapple Bucket (A65583)
New/Unused...
