PTO Chipper vs Tow Behind Chipper
/ PTO Chipper vs Tow Behind Chipper #21
That should be a good chipper for you. Usually - a larger chipper means a heavier fly wheel. Heavier fly wheel will give smoother operation.
/ PTO Chipper vs Tow Behind Chipper #22
If you are chipping green material with lots of sap - freshly cut pine trees - you DO need a larger chipper. Larger chipper will give higher air flow and clear the chips.
I did have trouble with the discharge chute plugging when I had the Wally BX42S. The chute would become coated in pine sap and the air flow could not blow the chips out this chute. Quick fix for this - have some dry wood to put thru to clear the chips and sap. Long term fix - fell the trees and drag to piles. Let them sit a year and chip then.
When I let the small pines sit a year - absolutely no problems with plugging.
/ PTO Chipper vs Tow Behind Chipper #23
So...... my bottom line. I've had both - stand alone and PTO chippers. I stayed with the PTO because - with the Kubota M6040 I have around 50 PTO Hp behind the chipper - one less engine to maintain - easier to get around in the woods with a chipper on the 3-point. AND any equivalent 50 Hp stand alone chipper is well beyond my financial means.
/ PTO Chipper vs Tow Behind Chipper #24
My experience with chipping is somewhat different than mikester. I thin my stands and drag all the downed pines to many piles. THEN - I begin chipping. I will chip for ten to twelve hours every day. Take a break every hour or so and rehydrate. Chipping will be all done in less than a week. The entire process - less than ten days.
Some times are easier than others. My son and his friend will, occasionally, drop by and give a hand.
This is how I thin my stands and chip 800 to 1000, or more, small pines.
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
TEST YOUR BID BUTTON! (A65053)
TEST YOUR BID...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
FLAT BED (A65643)
FLAT BED (A65643)
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
