Should I worry???
/ Should I worry??? #1
Jordan9682
Southwest sk
New holland 9682
image.jpgI'm thinking of buying this disc, its 33" wide and the discs aren't at a very aggressive angle. Should I worry about killing my quad? (Burning off the belt, ENGINE OVERHEATING, etc)
How heavy does this disc pull compared to a harrow? (How big of spike tooth harrow pulls about the same as the disc?)
Or will I loose traction way before then?:confused:
/ Should I worry???
Have no tractors under 100 horse
Useless how? Just don't go down?
As far as not going down, I can find a way to add weight to it
/ Should I worry??? #4
Looks like the king cutter I have. For breaking ground it's useless even with weight added. I pulled it with my Polaris 800 and it handed it well. Transmission got very hot but I never over heated or burned out a belt. Yes it wore the belt a lot faster and was **** on nearly every part of the atv driveline. It did over heat a friends Mule 610 (400cc).
The only way I could get it to cut was to rearrange the discs and do circles.
After a couple years of struggling I gave up on the disc and using an atv for a y serious work and bought a CUT last year. I'd be happy to sell you my atv disc so I can afford a real 3pt disc.
/ Should I worry???
Got one last week. I have 140lbs of weight on and im quite happy with it(im in sand so that probably makes it alot easier going down) will break up grass after a few passes. My quad pulls it quite easy, easier than i thought it would!
New/Unused ATS Cement Mixer (A65583)
New/Unused ATS...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
(1) 20 Yard Roll Off Dumpster and (1) 30 Yard Roll Off Dumpster (A65579)
(1) 20 Yard Roll...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
1997 Ford F-450 Dump Truck, VIN # 1FDLF47F6VEB26852 (A61165)
1997 Ford F-450...
2018 FORD F-150 (A65643)
2018 FORD F-150...
