Should I Be Using Overdrive When Towing?
/ Should I Be Using Overdrive When Towing? #41
Seems like most of the 3/4 ton and up trucks are already issuing these as standard equipment. Many of the half tons as well. My dodge and ford have them..
soundguy
JD4610 said:
I would also highly recommend a trans temp gauge for anyone that tows with their truck.
Jay
/ Should I Be Using Overdrive When Towing? #42
JD4610, thank you, thank you, thank you. You said it so much better than I did, I said "when it down shifts I push the button, when I get to the top of the hill I push the button". I just finished another run to Kentucky pulling my horse trailer. 1750 miles in 32 hours, using OD and cruise Hey there's another topic.:rolleyes:
Bake
/ Should I Be Using Overdrive When Towing? #43
Bake
Yikes.....cruise......please don't get us started:D:D
2008 Toyota Solara Convertible (A61569)
2008 Toyota Solara...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
VANAIR VIPER G60 COMPRESSOR (A60736)
VANAIR VIPER G60...
New/Unused 2in Ratchet Strap (A61166)
New/Unused 2in...
2012 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A60736)
2012 TROXELL...
New/Unused Mini Skid Steer Mounting Plate (A61166)
New/Unused Mini...
