Shop Tricks
/ Shop Tricks #181
Seems simple but I take care of about 75 engines, not all mine. I got a label maker for x-mas 10 years ago and I now put the oil type, filter number, wrench size, and qts required under the hood or somewhere in plain view like on my generator.
The labels read like this
6 qts/15W40/14MM/PH3950
Chris
/ Shop Tricks #182
Chris
In addition, I write the recommended oil / filter change schedule.
/ Shop Tricks #183
At the mechanics shop here in the city where I work, they write the date and machine hours (or milage) right on the filter telling when it was last changed. They also use some type of paint pen to write the tire pressure on the wheel next to the valve stem.
/ Shop Tricks #184
That is what I did: 6 qts/15W40/14MM/PH3950
Give you quantity, oil grade, wrench size, and filter.
On equipment I right the date and hours on the filter. Do not bother on cars and trucks. I also used the label make to print labels for lug nut torque and tire pressure and placed them on the fenders on all my trailer and equipment. In my cars and trucks I put it inside the door next to the data plate.
Chris
/ Shop Tricks #185
...Give you quantity, oil grade, wrench size, and filter...
Chris
I think he was saying he writes the change interval, Like "100 hrs." or "3K Mi."
/ Shop Tricks #187
Have you used these to mark metal to be cut/welded? Do they remain visible after being heated? How thick is the line it makes?
Thank,
Clem
Actually, this was the original intention when my wife got them for me but they do leave a wide (approx 1/4") mark that doesn't always have a perfectly defined edge, which isn't good for precise cutting. Even when using a straight edge, they will sometimes bleed just slightly under the edge. I use them on metal all the time for all types of purposes but I usually use a scribe when marking metal cuts. They will tolerate a fair amount of heat but exact temps I couldn't speculate on. I do know they still work in sub zero temps.
/ Shop Tricks #188
I keep my oil changes on the even "100 Hr." for the tractor. The truck goes on even "10,000 Kil.". And the car when the "Change oil " light flashes.:D
/ Shop Tricks #189
Rechargeable batteries - NiCad and NiMh. I have a ton of the AA and AAA type. I also have adapters that will let you use the AA in the place of a C or D cell.
At some point in time these stop taking a charge. Some people erroneously call this the memory effect. What is really happening is that there is a crystalline growth inside the cell that shorts out the internal workings of the cell. With a quick large burst of current you can blow away this crystalline structure.
For batteries that will no longer charge on your charger, you can revive these with a car battery charger. (Caveat: I've been doing this for close to 20 years never had a problem, but wear a face shield and leather gloves for safety if you are paranoid). OK, so what you do is put the car battery charger on 10A manual mode. Put the red (+) clip on the table / workbench. Now hold the AA battery with the positive (+) side against the red clip. Take the black (-) clip and tap it against the negative (-) side of the battery. DON'T HOLD IT THERE! You'll see the current meter on the charger jump to 8-10A and back to 0, and you'll get some sparks. Repeat this 10-20 times, just quick little taps. If you feel the battery getting warm, STOP!
This technique also works with portable tool batteries (drills, saws, etc) provided you can take the plastic battery case apart and get to the individual cells. My original 12V batteries for my Makita drill I got in 1995 *still* take a charge.
I've read on here and other places about the de-sulphating of car batteries, and I believe this is a similar process, but I've never tried one of those units on a dead AA battery.
Buyer beware, caveat emptor, safety nazis abound, do at your own risk, yada yada yada. Like I said, 20 years, never a problem, but be careful and don't over stress the battery. If it is bulging, don't try this trick! If it is leaking, toss it. Don't try this on alkaline batteries.
Last night I gave this a try on a 14.4V that has been dead for about 2 yrs. I measured it w/meter and it shower .0 V then quickly jumped it w/ a good 19.2 several times and it showed 8v. I put it in the charger and it still wouldn't do anything...even show as defective. I put the jumpers back on it and touched it to a huge 950 amp 12V battery I have hoping to "shock" it a couple of times and it showed about 12V after that but still wouldn't work in the Craftsman quick charger. I then connected the jumpers to my 12V automotive battery charger @ 10 amps and left it for about 2 hrs......miraculously when I checked it it showed over 14V and spun the drill like there was no tomorrow ( don't know how a 12V charger can bring it to 14+V, but it did. I put it back in the Craftsman charger and it still doesn't register default,charge or full charge but it is working again. I'll just use the jumpers/auto charger from now on and see what happens but for now it's working again.
/ Shop Tricks #190
Careful - you can over charge these, and they will melt when you do so. The "zap" trick works on individual cells, when you take the battery apart. The 14.4V battery has 12 of the 1.2V battery cells in it.
But, it sounds like maybe you have the battery going again, so good deal. I suspect your 14.4V charger might be bad, though.
/ Shop Tricks #191
Yeah, when "jolting" them I did quick jumps and while on the automotive charger, I stayed in the garage while it was charging and checked it periodically while it was on. I had actually tried "zapping" it once before and then tried to use the factory charger but to no avail. The automotive charger seemed to have made the difference. I was originally going to take the battery apart, identify the bad cell(s) and replace them....just never got around to it. The charger is a Craftsman quick charger that is the "universal" model for all their newer batteries including the 14.4V and 19.2V. It works fine on my other 14.4 and 19.2 batteries, just doesn't show anything on this particular battery.
/ Shop Tricks #192
Thank,
Clem
Hey Clem,
I use whiteout pens (available at the office super stores. So far it's worked great with my plasma cutter.
Mike
/ Shop Tricks #193
Hey Clem,
Mike
Mike,
I had forgotten about that. I read somewhere that the lines that are not cut remain visible, even with all the heat around it.
Thanks,
Clem
/ Shop Tricks #194
I don't know if someone has mentioned it yet but for marking cut lines on metal I have often used a center punch and rap a dot at intervals along the cut layout line. The tighter the curve the closer the interval.
Many times I use a template for cutting especially if I need more than one identical part. I normally use a scrap of 3/4" plywood or particle board for the template. They will last for several cuts until the edges become too charred to reuse.
My pattern often comes directly from my CAD drawing and I'll use an offset line equal to my 1/2 cutting tip to make the template pattern the correct size. I have a 24" wide plotter with roll feed so I can make pretty big patterns this way. I spray adhesive that pattern on the template board then cut out on the bandsaw. Graph paper, freehand or mechanical drawings would work too and a jig saw if you don't have a bandsaw.
If I know my template will not last for the number of duplicate parts I need I just nail or screw several template blanks together and cut them all at the same time.
If you have a part and want to make a cutting template from it you can make a precise negative template by using a flat washer that has a wall 1/2 the thickness of your torch tip. Place the part on the template board and the flat washer touching the part. Put you pencil or pen in the hole of the washer and run it around the part always keeping contact with the part. You'll have a template that is now 1/2 torch tip bigger than your part. Cut with bandsaw or jig saw and use the negative image as your cutting guide.
We'd also use this method for making an exact fit router template. The washer wall would be the difference between the router guide collar and router bit.
The washer spacer trick also works great if you are trying to make any piece bigger, say a mounting board for an oval plaque with an even 1/2" reveal all around or a backing plate for a hydraulic valve that has an irregular footprint.
/ Shop Tricks #195
i do the zap trick alot
but plsss be very careful
one time i had a DeWalt 14.4 battery that would not charge and did the very same thing yall are talking about worked fine first 4 or 5 times and then one day hooked it up like always and went inside to get a drink and "bang" "bang"
holy---- sound like a 410 shotgun outside my door
the top of the battery pack had blown off and nowere to be seen. 2 cells popped and made a really bad ugly stain on my wooden door in about 60 different spots all the way up the door
if i had been out side still like most the time (holding the battery)
well you know that would not have been good on the skin or in the eyes
so i dont do that little trick anymore
and i know what your thinking
no i didnot hook it up rong i had made it were it only would go in one way
and had it only on a 2amp setting
i checked lol
be careful guys
now i just take um and when i get 2 bad take um apart and test each one find the bad cells and replace with one that tested good from the other one
that works better for me
i have also taken all the cells out drilled a small hole in the side ran wire to the hot side and neg side and made the wires really long with a cigarette lighter plug end and use it a lot when just doing stuff at the truck (the drill was a 12v )
gary...
/ Shop Tricks #196
Diagraph, of course, is the first class way of permanent marking on anything made. Second choice (cheap) is paint sticks that they sell at the lumber yard. I keep a full set of all colors around just for things like you need to mark now.
One word of caution though, once marked, you'll play heck washing them totally off. BTW, they're great for marking tool size imprints. Just rub them across the size stamp, wipe across them with a paper towel, and let them dry.
I really like the idea of using the paint sticks for marking tool size imprints.
A lot of times I work in low light areas, and it would really be handy to easily see the wrench & socket sizes. Maybe even using one color for SAE & one for Metric to keep them from getting mixed together.
I have a question though.
Are you talking about the paint sticks that are like a big crayon that has a consistency of almost dryed paint, or the kind of paint markers that has liquid paint and uses either a felt tip or roller ball?
I think Markal makes both kinds that I've seen in lumber yards.
Ronnie
/ Shop Tricks #197
yep - Markal is the brand. They're just paint sticks, available in about 8 colors for about a buck each.
/ Shop Tricks #199
Very good tips RedDirt!:)
/ Shop Tricks
Forgot to add...
Best way of storing chain oil for chain saw is in an old Dishsoap container (Dawn, etc.) These have a snap cap and allow you to point the spout upside down before anything comes out. I keep all my chain oil, files & tools in a milk crate for easy toting access when I cut stuff up.
49T&C
1605 (A57192)
1605 (A57192)
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
Hydraulic Tilt Bucket Mini Skid Steer Attachment (A59228)
Hydraulic Tilt...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
2015 Chevy Cruze Sedan (A59231)
2015 Chevy Cruze...
