BravoXray
Elite Member
- Joined
- Dec 17, 2019
- Messages
- 3,631
- Location
- Nothern Indiana
- Tractor
- Kubota BX2230, John Deere 430 Diesel
How about some engineer comedy?
They have. Gen-X and older tend to be more competitive, whereas the Millenials and younger tend to be much more collaborative. What's interesting is that I'm old enough to work with some pre-Boomers ("Silent Generation"?), and they were also less competitive and more collaborative than the Boomers thru Gen-X that were my primary peers.Kinda off, but about engineers... I used to hate them, and now, I get along fine with most. Part might have been age, but I do think engineers have changed over the years.
I worked with A-holes like this. Usually a sign of someone with weak technical skills, when they bristle over having to make a few changes, or feel unnecessarily threatened over having their numbers questioned or challenged.He looses his dang mind that a 25 year old superintendent dared change his plans. He changed all of my grades by like 0.1 or so, and send them back, with a smart butt response.
It's going to depend on the industry. In my world of manufacturing and R&D, no one gets a PE. To date, I can only recall one PE among all of my prior colleagues, and everyone would constantly ask the guy why he got a PE.I know not all folks that get mechanical or electric engineering degrees bother to become a PE, but ive pointed out to her, a PE is a PE.
I guess Third times a charm replaced cheap plastic shower wand with a new cheap plastic shower wand and this time I put away the pipe wrench only hand tightening it using my hands only plus the rubber washer /gasket and no cracks or leaks for now. I Searched local Hardware stores opening the boxes of more expensive ones thinking I'd see a metal coupler to screw on shower spout, nope all plastic I couldn't find one anywhere local anyway.More to do with me being a bull in China shop and wannabe diy plumber, installing a simple second shower Wand in my cabins upstairs shower first one I replaced was all metal and fine when I built the place but I tiled surround around top of fiberglass shower walls recently so I replaced shower wand over tightened cracked the plastic screw in fitting to shower down spout think I learned my lesson? nopecracked second new shower wand plastic screw in fitting. Less is more for cripes sakes. Feel I'm spending our families retirement fund in shower wands lol. Third time's a charm I hope. Wish I could find one with a metal screw in fitting to shower down spout coming out of wall. Why does the the shower engineer dept ,and bean counters feel the need to use so much plastic on a device that's used daily? Why did I replace the first all metal fitting wand? Maybe I can retro fit existing components of original wand or just reinstall all metal old fitting and be done with it.
I was a design engineer and got a PE. It was just a personal goal. I really never needed it. The legal dept would look for PE's if they needed someone to testify. Typically though, they'd hire an outside "expert" and have them get all the background from staff engineers. Fine by me! Just before retiring they started requiring annual re-testing to maintain the certification.... I let mine drop.It's going to depend on the industry. In my world of manufacturing and R&D, no one gets a PE. To date, I can only recall one PE among all of my prior colleagues, and everyone would constantly ask the guy why he got a PE.![]()
That's really surprising. I have HID's in two of my Dodges, likely many of the same components as Jeep, one is 9 years old and zero issues. I also had HID's in a Volvo that we kept for 12 years and something like 200k miles! Zero issues.My Jeep GC has HID headlights, they need to be replaced every 3-4 years.
The driver I only had to replace one on one side, that is the item you need to remove the whole front bumper and grill assembly to replace to get to the one screw that allows the headlight assembly to be removed since the driver is on the bottom of the headlight assembly instead of on top.
Lifespan probably depends a lot on how many hours they are used, not calendar age.That's really surprising. I have HID's in two of my Dodges, likely many of the same components as Jeep, one is 9 years old and zero issues. I also had HID's in a Volvo that we kept for 12 years and something like 200k miles! Zero issues.
Interesting concept, gotta wonder how they handled fuel lines, engine output shaft, exhaust and throttle linkage.I'd buy this engineer a beer or 3.
You mentioned the same questions I had.Interesting concept, gotta wonder how they handled fuel lines, engine output shaft, exhaust and throttle linkage.
Sure makes maintenance a lot easier than most of the 60s/70s vintage vans where the engine was between the driver & passenger.
Think generator not vehicle engine and it all works.Interesting concept, gotta wonder how they handled fuel lines, engine output shaft, exhaust and throttle linkage.
That's where my mind went, until I wondered about the exhaust connections. Seems a parting coupling could be made for that, but such things don't always weather well under a vehicle.Think generator not vehicle engine and it all works.
I would tend to think that the exhaust would be self contained within the confines of the cradle that the engine slides out on. I would think that it would only run when the motor home is parked.That's where my mind went, until I wondered about the exhaust connections. Seems a parting coupling could be made for that, but such things don't always weather well under a vehicle.
I had a 66' GMC with a six banger. It was actually not bad to work on. I bought it as a shell sitting in a field. LOL, it was used for some kind of fruit/vegetable business and every door was boogered up. I got doors all over the place. Looked like Joseph's tecnicolored coat. I pieced together an engine, 3spd, bell housing, etc. To put the engine in, I laid the engine on it's side, rolled it under, stood it up and jacked it into place. It was far easier to work on than my E450 box van with a V10.Interesting concept, gotta wonder how they handled fuel lines, engine output shaft, exhaust and throttle linkage.
