Those #+%^ engineers!
/ Those #+%^ engineers! #142
Kinda off, but about engineers... I used to hate them, and now, I get along fine with most. Part might have been age, but I do think engineers have changed over the years. Starting in construction, some grades wouldn't work, mark up the plans with new driveway grades and fax then EOR to get approval. He looses his dang mind that a 25 year old superintendent dared change his plans. He changed all of my grades by like 0.1 or so, and send them back, with a smart butt response.
Thats the type I dealt with at first.
Then, during a slow period at the county, me and another inspector are given busy work of looking at 177 failing roads in our county, get lane miles, widths, cross drains, ect. Get back, and hand him the info on day 1; "yeah, great, I can get that on Google Earth, what do we need to do? Level and over lay, chip seal, micro pave, reclaim in place?" Was a guy in maybe mid 40s, PE. that actually wanted someone's opinion.
Nowadays, I see that mostly as the norm. Now, I kinda caution people, you Think the design is wrong/stupid, but there might be a reason. Most of the old "im the engineer, dont question anything" have died off, and the newer generation is much more open to opinions. Also part, im not a 25 year old superintendent anymore.
Had a job about 18 months ago, me, contractor and some other guys meet, engineer is there, and it doesnt make sense. Site is already Well above all the surrounding properties, and they are picking it up 3 ft more, making driveway, ADA, ect very very tight, like has to Perfect to work. I ask, any reason to pick this entire site up, seems like rising 1 or 2 ft would be fine? Yeah, its 10 acres, but to make the free-board on the pond work, with only using 5 of the 10 acres, he had to pick up the site. Owner wanted to make sure the other 5 wasnt needed for ponds, so he could sell the remainer.
Point being, seemed dumb, but there was a reason. So, they spend $30,000 importing fill; but you can sell the 5 acres of commercial property left over for $100k.
/ Those #+%^ engineers! #143
In my daily experience now, its not at all unusual to ask an engineer what they think of a problem, or somethings that not right, and them ask "do you think it will work",
/ Those #+%^ engineers! #144
My niece is working towards a mechanical engineering degree, and minoring in electric. Both good fields, even if she is the "wants to save the world" stage, wanting to design renewable engineer systems. I know not all folks that get mechanical or electric engineering degrees bother to become a PE, but ive pointed out to her, a PE is a PE. You can SnS shed truss plans in a pinch; get the EIT and PE, even if you dont plan on using them.
/ Those #+%^ engineers! #145
They have. Gen-X and older tend to be more competitive, whereas the Millenials and younger tend to be much more collaborative. What's interesting is that I'm old enough to work with some pre-Boomers ("Silent Generation"?), and they were also less competitive and more collaborative than the Boomers thru Gen-X that were my primary peers.
There's good and bad in both modes, but of course the more collaborative types make for a more relaxed and less confrontational working relationship. :D
I worked with A-holes like this. Usually a sign of someone with weak technical skills, when they bristle over having to make a few changes, or feel unnecessarily threatened over having their numbers questioned or challenged.
It's going to depend on the industry. In my world of manufacturing and R&D, no one gets a PE. To date, I can only recall one PE among all of my prior colleagues, and everyone would constantly ask the guy why he got a PE. :ROFLMAO:
But my father worked in civil and plant engineering (factories, not flowers), and he and every engineer on his staff had to have a PE in each state in which they operated. Very different industry.
/ Those #+%^ engineers! #146
More to do with me being a bull in China shop and wannabe diy plumber, installing a simple second shower Wand in my cabins upstairs shower first one I replaced was all metal and fine when I built the place but I tiled surround around top of fiberglass shower walls recently so I replaced shower wand over tightened cracked the plastic screw in fitting to shower down spout think I learned my lesson? nope 😡 cracked second new shower wand plastic screw in fitting. Less is more for cripes sakes. Feel I'm spending our families retirement fund in shower wands lol. Third time's a charm I hope. Wish I could find one with a metal screw in fitting to shower down spout coming out of wall. Why does the the shower engineer dept ,and bean counters feel the need to use so much plastic on a device that's used daily? Why did I replace the first all metal fitting wand? Maybe I can retro fit existing components of original wand or just reinstall all metal old fitting and be done with it.
I guess Third times a charm replaced cheap plastic shower wand with a new cheap plastic shower wand and this time I put away the pipe wrench only hand tightening it using my hands only plus the rubber washer /gasket and no cracks or leaks for now. I Searched local Hardware stores opening the boxes of more expensive ones thinking I'd see a metal coupler to screw on shower spout, nope all plastic I couldn't find one anywhere local anyway. 🤞 It works for a few years. I really dislike supporting companies that are lackluster in making quality bathroom components. Oh well.
/ Those #+%^ engineers! #147
I was a design engineer and got a PE. It was just a personal goal. I really never needed it. The legal dept would look for PE's if they needed someone to testify. Typically though, they'd hire an outside "expert" and have them get all the background from staff engineers. Fine by me! Just before retiring they started requiring annual re-testing to maintain the certification.... I let mine drop.
/ Those #+%^ engineers! #148
I had to have a PE for my job. It got to be a nuisance when they started requiring continuing education credits (to support training companies) and ethics courses (to please the knee jerk politicians).
/ Those #+%^ engineers! #149
My Jeep GC has HID headlights, they need to be replaced every 3-4 years.
The driver I only had to replace one on one side, that is the item you need to remove the whole front bumper and grill assembly to replace to get to the one screw that allows the headlight assembly to be removed since the driver is on the bottom of the headlight assembly instead of on top.
/ Those #+%^ engineers! #150
That's really surprising. I have HID's in two of my Dodges, likely many of the same components as Jeep, one is 9 years old and zero issues. I also had HID's in a Volvo that we kept for 12 years and something like 200k miles! Zero issues.
/ Those #+%^ engineers! #151
Lifespan probably depends a lot on how many hours they are used, not calendar age.
/ Those #+%^ engineers! #152
I'd buy this engineer a beer or 3.
/ Those #+%^ engineers! #153
Interesting concept, gotta wonder how they handled fuel lines, engine output shaft, exhaust and throttle linkage.
Sure makes maintenance a lot easier than most of the 60s/70s vintage vans where the engine was between the driver & passenger.
/ Those #+%^ engineers! #154
You mentioned the same questions I had.
/ Those #+%^ engineers! #156
Think generator not vehicle engine and it all works.
That's where my mind went, until I wondered about the exhaust connections. Seems a parting coupling could be made for that, but such things don't always weather well under a vehicle.
/ Those #+%^ engineers! #157
I would tend to think that the exhaust would be self contained within the confines of the cradle that the engine slides out on. I would think that it would only run when the motor home is parked.
/ Those #+%^ engineers! #158
Years ago a friend was a mechanic for a nearby city working on their Neoplan buses that gave lots of trouble. He said they were rear engine with a short driveshaft to differential. One day going down a long hill a U joint broke and the driveshaft whipped around until it beat it's way through the floorboard. Luckily no people were in seats above but two old ladies in seat behind. He said they were understandably terrified but unhurt.
They hired this big strong muscular guy who was the bottom of a hill one day when workers had to change a flat tire. "Just roll it to me & I'll catch it!" he said. The workers argued a bit finally said okay. The big guy tried catching it but fell back with a loud "Ooommmphh!". He was OK but embarrassed.
/ Those #+%^ engineers! #159
I had a 66' GMC with a six banger. It was actually not bad to work on. I bought it as a shell sitting in a field. LOL, it was used for some kind of fruit/vegetable business and every door was boogered up. I got doors all over the place. Looked like Joseph's tecnicolored coat. I pieced together an engine, 3spd, bell housing, etc. To put the engine in, I laid the engine on it's side, rolled it under, stood it up and jacked it into place. It was far easier to work on than my E450 box van with a V10.
/ Those #+%^ engineers! #160
I don't know if an experience at Kroger today can be blamed on an engineer or a bean counter or both? Never happened before today either. Anyway, as i walked into the store, someone was coming out. An alarm went off and I heard him say something about his cart wheels locking up. Wanting to get in and out, I walked on, got my stuff, did the self check out and when I went through the door, the alarm went off and my cart wheels locked up. The clerk that was watching over the self check came over, turned off the alarm which released my cart wheels and said something about a computer sensing that I did not spend enough time checking out. I realize that retail theft is a big issue but I think that they need to go back to the drawing board.
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A63118)
BOSS 990 Fuel...
UNUSED KJ 45'X25' DBL GARAGE STEEL BARN SHED (A62131)
UNUSED KJ 45'X25'...
2016 Dodge Charger Sedan (A61569)
2016 Dodge Charger...
New/Unused Quick Attach Pallet Forks (A61166)
New/Unused Quick...
Single Arm Ripper Excavator Attachment (A61567)
Single Arm Ripper...
Four (4) R207782 John Deere Wheel Weights (A63116)
Four (4) R207782...
