Shop Lift
/ Shop Lift #81
Hazel,
I have the Hd9-XW. Its awesome. The rolling oil funnel thingy is key, I tried using my oil pan on the Jack plate but it’s too awkward for your arms to work around to get to the drain plug.
the oil funnel on wheels was only about 100 bucks.
  • Good Post
Reactions: JJT
/ Shop Lift #83
I'm guessing at the ceiling height. When he has a Chevelle or GTO on the lift the wheels are at chest height. I couldn't work under it without a rolling chair but he seems to do OK.
I'd struggle with that. If I raise my 4 post all the way it's too high to do almost all maintenance tasks.
/ Shop Lift
Hazel,
I see what your saying about it being awkward and I figure it would splash out too.
I bought this one a few years ago, have been really happy with it. 20 gallon Portable Oil Lift Drain
Sent from my SM-G715U1 using TractorByNet mobile app
Yep I may have to visit Harbor Freight, that one is probably bigger than I need but then that could be a good thing.
/ Shop Lift #85
Mine is 5 gallon. I wouldn't want it any bigger. Too hard to move and/or empty. Mine is plastic with molded handles, spout, telescoping tube, 20" plastic funnel with a screen to catch the plug that you will most definitely drop. It's got a weight built into the bottom so it doesn't try to tip over.
/ Shop Lift #86
That's one of the nice parts of the 20gal, don't have to empty it often, and when you do it empties via compressed air so no picking it up!
/ Shop Lift #87
Yep. My Son makes a living as a mechanic. He has one of those. I'll only generate about 50 gallons of used oil off my hoist a year. My small one works great.
/ Shop Lift #88
I also added one of these, comes in handy for keeping spills to a minimum, also helps if you have to drop a trans pan or diff cover.
/ Shop Lift #89
BendPak gave me this one free when I ordered my lifts:
When you take it to empty/recycle, does the shaft come off and is there a cap, so it doesn't splash all over the truck?
/ Shop Lift #90
Yes, the drain tube slides out and the opening can be capped.
There is also a hand crank pump which lets you transfer the used oil into other containers. I usually pump the used oil back into the 2.5 gal jugs the new oil came in. It makes it easier to transport without making a mess.
/ Shop Lift #91
Many of those lift oil drains have valves so you can use shop air to pump the oil out into the recycling container.
  • Good Post
Reactions: JJT
/ Shop Lift #92
I see u made your choice, it will be a great addition for you.
I went with Mobile column lifts after much consideration a few years ago
Wireless, cordless, 13k lbs per column (52,000 lb total), stay against the wall when not in use, roll anywhere to use, frame end lift or wheels. I like them
/ Shop Lift
That is Awesome
/ Shop Lift #94
I never got past the picture of the "inny". :cool:
/ Shop Lift #95
Geez those must have set you back a bundle, plastikosmd...
/ Shop Lift #96
Bit more than the monarch 2 post that I was considering
was able to save a bit not having to spec the floor up for the 2 post
also worth $$ not tripping over lift
But agree, not for everyone
/ Shop Lift
My lift has been sitting in Atlanta Georgia since Friday waiting on a 2 hour drive to Birmingham Alabama where I can pick it up. I asked the lady if I could just pick it up in Atlanta and she said no, so here I sit knowing it is just 2 hours away and I can do nothing but wait.
/ Shop Lift
I went and picked up my lift and this thing is heavy but I hope to get it together soon. With family obligations it may take me as long to get it together as it did for them to ship it. o_O
/ Shop Lift #99
Looking forward to pics and stories!!!
/ Shop Lift #100
I was able to install my 4 post in a weekend, alone. I used a shop/engine hoist to pick things up and 4 wheeled dollies to move things around. Slow and steady, less than 12 hours from pieces on a pallet to having a working lift with a car off the ground. Two people can do this in 4 hours if they know what they are doing. Read the instruction twice.
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
2022 Magni TH5 5.19P (A63689)
2022 Magni TH5...
Luck Now XLR 4750ST (A64126)
Luck Now XLR...
SANY EXCAVATOR (A63276)
SANY EXCAVATOR...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A62130)
(INOP) 2013 MACK...
(2) Firestone 282-26 Tires w/Rims (A64127)
(2) Firestone...
