Shibaura Engine running generator
   / Shibaura Engine running generator #71
This is what I did earlier this year to troubleshoot a starting issue on a (new to me) generator.
DSC04795b.jpg Primitive I know.
Process of Elimination.
Known Good Mule Battery (Only Walmarts Best!)
No Go!
Took that bare copper wire and went onto the block. Unit started. Then found bad ground connections to block.
Funny, because when I was trying to use a Charger/Starter, the unit was throwing overvoltage codes. It's easy to get confused. Short high quality jumper cables can be very useful. I have a couple only three feet long, that I have used often.
The previous starter was still in the garage so I decided to take it apart and see what was going on as of Dec. 2017 when I got the new one. It was full of carbon dust. I cleaned it up and sanded the armature and commutator and the brushes were worn but looked usable. I did not have a replacement set. I put it back together and hooked up 12v and it jumped and whirled when I applied power. It did not get hot or sound funny either. The case and mounts were corroded like the newer one I just took out. I cleaned those up too. Now I want to see if it will crank the engine. Still want to get both of them tested though. I will also try my new HF Bat Load Tester on them while cranking. I found a way to temporarily mount and un-mount the starter that males it much easier to test.
Update.
I took both starters to an alternator/starter shop and they bench tested them and they both had bad armature wiring. So I have ordered a new one off Ebay from DB Elecetric.
I also took the starter solenoid out (a bear to do) and tested it. It appears to work correctly to me. It passes thru almost exactly whatever voltage I put on it (12.5v static or 14v if alternator is running on the car).
I load tested it with the new HF Bat Load Tester and it passed thru 10.5v under load. Someone on here I think said anything above 9v should start the engine.
Does this seem like a good solenoid to you?
   / Shibaura Engine running generator #74
Update.
That should be good on the solenoid, my question though would be what was the voltage coming into the solenoid versus the voltage going out of the solenoid.
Aaron Z
   / Shibaura Engine running generator #75
A solenoid should be tested with volt/ohm meter.... Its either its open (not energized) and should indicate "infinity".... Should have "0" ohms resistance (or close to it) energized... Keep in mind it's just a switch, it either energises or it does not, it either makes "contact" across terminals or does not....
Contacts can be marginal with pitting from abuse of trying to many start with anything less than optimum conditions....
Dale
Dale
When energized I get 0.00 Ohms across the main terminals. Voltage is the same on input and output terminals when energized. Whatever voltage it receives it passes through. The solenoid was replaced with the starter 1.5 years ago so it has had limited activity since it would seldom start. The contacts would have been closed for longer than usual each time I tried to crank it since it would not start. This test seems to say the solenoid is good.
Update.
I finally got the new starter in and tried it out today. I have made several tests and it will turn the engine over if:
1. I am running 14v to it from car battery (HD jumper cable with ground to various points, the only way I have tried so far) and
2 I have the (+) connected directly to either the starter or the output from the solenoid.
It will do its old trick if I do anything else. I don't want to try too many times as that is probably what burnt out the other 2 starters. It will not turn the engine over if I do not have the car running (14v) which may say that anything less than 12.6v might not be enough for this thing. My car battery is a little low at the moment as I don't drive much (retired) and sometimes the battery drops below 12.6v and I have to put a charge on it. I think it may have been 12.2v today, so I ran the alternator while testing.
That seems to tell me the solenoid is bad and not letting enough amps thru to the starter. I ordered a new solenoid today and it should be in this evening.
I have cleaned all contact points again relating to the genset. The ground from the jumpers I have tried in different scenarios so I think the ground is okay at this point. I do have an additional battery cable (ground) from the starter bolt to chassis frame ground.
I have isolated the testing to my car battery and not included the motorhome cables or batteries yet. When I get it running, I will start hooking those back up and see what happens.
It did actually run twice while I was testing with the solenoid in line but would not restart afterward.
   / Shibaura Engine running generator #78
Still seems like you have large voltage drop on the [ + ] or [ - ] battery cable(s) path from the RV battery box to starter motor. Only takes one bad cable with corrosion inside the cable or one bad ground connection to or from the RV frame. Should be able to find the bad [ high resistance cable ] by checking voltage drop across cable when cranking engine. Cable shouldn't cause more than 1th to 3th of a volt when cranking engine. Which city / state are you in?
   / Shibaura Engine running generator #79
How may times have you been told the batteries and cabling (30 Ft) in MH are probably a good portion of your starting issues... That is probably why you smoked the starters....
To wit...
Last friday nephews car would not start (11:00 pm in his work place parking lot), solid battery, everything pointed to bum starter, had it towed..... Saturday morning 4-5 hours including trip to AP plus $121 for reman. starter, put new starter in car....Problem persisted.... Even put known good battery from Jeep (900CCA AGM) jumped to his battery... No go, starter pulled system down to just about 6 volts jumpers got warm ???????... Went with starter as problem because everyone said starter.... And a 100 miles (2 round trips to take him to work and pick him up saturday) ...
Put battery charger on his car and it sat overnight...
Sunday morning managed to get car started.... Horrible hammering noise under hood... WTH??...... Shut car off.... Open hood, nothing looks bad... Start car, no noise, shut car off, start car again no noise, no wait here it comes hammering sound from alternator.....Pop serpentine belt off, everything is quiet and motor starts and runs sweet...
Another $151 dollar for reman alternator and 4 hour fighting the thing and $270 later ... car fixed..... Seems bearings were going out in alternator, and with alternator jammed and serpentine belt with really tight grip, the actual starting problem was alternator locking things up...DUH!
Just because you have certain symptoms does no always accurately identify problem.... Solution look further....
Personally I think replacing ground cable from battery to MH frame and ground strap from MH frame to engine of gen. would be next try at fix and least expensive ...... IF no love there replace long cable from battery to solenoid with welding cable and just for "ducks" go one gauge larger than what is there now and make sure every connection is clean shiny bright and when assembled all connection are protected by anti corrosion grease....
Dale
   / Shibaura Engine running generator #80
OP, did you read my post #5?
From your last post, you do not have fully a fully charged Battery.
State Of Charge Reference Chart
Percentage of Charge12 Volt Battery24 Volt BatterySpecific Gravity
10012.7025.401.265
9512.6425.251.257
9012.5825.161.249
8512.5225.041.241
8012.4624.921.233
7512.4024.801.225
7012.3624.721.218
6512.3224.641.211
6012.2824.561.204
5512.2424.481.197
5012.2024.401.190
4512.1624.321.183
4012.1224.241.176
3512.0824.161.169
3012.0424.081.162
2512.0024.001.155
2011.9823.961.148
1511.9623.921.141
1011.9423.881.134
511.9223.841.127
Discharged11.9023.801.120
As indicated, a 12 VDC battery at 12.2 volts is only 50% charged.
Towable Dewatering Pump (A59228)
Towable Dewatering...
KBH 25T Tender (A56438)
KBH 25T Tender...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Freighliner Tender Truck (A56438)
Freighliner Tender...
Utility Cart (A59231)
