Seat switch bypass
/ Seat switch bypass #51
Not one of those cases made a good case for seat safety switches. How about you don't try to start a tractor standing on the ground. Ok I admit, I have done it. There are other far less annoying safeties to prevent that anyway. Modern tractors have a safety requiring the tractor to be in neutral and the clutch be pushed in to start. I disabled the seat safety, but those safeties are still operational. How could a roll over be prevented by a seat safety? Posting those served no purpose.
Not true, the seat safety switches are also there to prevent starting the tractor with the operator's foot, clothes, or limbs entangled in the PTO, or at risk of being so.
Also my HST tractor doesn't require it to be in neutral or have a clutch depressed to start, but it is supposed to require an operator presence, or at least have the seat switch engaged.
So some of the articles cite rollovers- every one of them that I included also cites injuries or deaths caused by defeating safety interlocks.
So some weren't necessarily the seat interlock, SO WHAT-to me, safety is the question, and the answer was clear in EVERY SINGLE article- a DEATH or SERIOUS injury was the result of someone havjng been in too much of a hurry, or too lazy, or too inconvenienced to run the tractor or skidsteer as designed-with the safety interlocks operating.
The most criminal thing to me were the cases where the defeated interlock was caused by a PREVIOUS OWNER- more evidence that it isn't just your own health and life you are potentially risking.
4570,
If you think my post was purposeless, then DON'T READ IT, and for GOD's sake DON'T follow the links.
It wasn't intended for the apparently close-minded types who have already decided what they want to do, are just here trying to justify their choice, and can't be swayed by reason and logic, it was posted for people who haven't come to a conclusion and WANT to learn and understand.
You may not accept this, but until I read some of these (and make no mistake, the links I posted were just a few from a single VERY cursory search), I have been entertaining thoughts recently of disconnecting our seat interlocks because of the problems listed in my previous post, but having read them, I am instead going to have my dealer investigate our tractor and see if an electrical fault is causing our problems.
DENIAL is not just a river in Egypt.
/ Seat switch bypass #52
My tractor will not start if the clutch peddle is not depressed or if the PTO switch is on.
Never had a seat switch. Guess I better park the thing.
/ Seat switch bypass #53
The key switch will do the same thing as that the seat switch will do. I recommend an auto air shut off switch for when the tractor tips over.
How will the key switch AUTOMATICALLY switch off the tractor if it rolls over?
Also for those who may not understand, the motor off seat safety switches AREN'T there to protect the motor, they're to protect YOU from being caught and pulled into and under the rotating tires, which could occur, should the tractor overturn and the motor not shut off while the "gears" or transmission is engaged, and you either fall off the seat (not wearing seatbelt- which is critically necessary to let the ROPS protect you) OR if you rolled over, and unhooked your seatbelt before remembering to turn off the (un-magical/non-automatic) key switch (which most of us are stuck with).
/ Seat switch bypass #55
Not true, the seat safety switches are also there to prevent starting the tractor with the operator's foot, clothes, or limbs entangled in the PTO, or at risk of being so. Also my HST tractor doesn't require it to be in neutral or have a clutch depressed to start, but it is supposed to require an operator presence, or at least have the seat switch engaged. So some of the articles cite rollovers- every one of them that I included also cites injuries or deaths caused by defeating safety interlocks. So some weren't necessarily the seat interlock, SO WHAT-to me, safety is the question, and the answer was clear in EVERY SINGLE article- a DEATH or SERIOUS injury was the result of someone havjng been in too much of a hurry, or too lazy, or too inconvenienced to run the tractor or skidsteer as designed-with the safety interlocks operating. The most criminal thing to me were the cases where the defeated interlock was caused by a PREVIOUS OWNER- more evidence that it isn't just your own health and life you are potentially risking. 4570, If you think my post was purposeless, then DON'T READ IT, and for GOD's sake DON'T follow the links. It wasn't intended for the apparently close-minded types who have already decided what they want to do, are just here trying to justify their choice, and can't be swayed by reason and logic, it was posted for people who haven't come to a conclusion and WANT to learn and understand. You may not accept this, but until I read some of these (and make no mistake, the links I posted were just a few from a single VERY cursory search), I have been entertaining thoughts recently of disconnecting our seat interlocks because of the problems listed in my previous post, but having read them, I am instead going to have my dealer investigate our tractor and see if an electrical fault is causing our problems. DENIAL is not just a river in Egypt.
There is a safety in the HST pedal that requires it to be in the "neutral" position to start. Being in a hurry or lazy was the cause of every single one of these accidents not the lack of safety crap. I have started a machine several times be shorting across the starter, and EVERY SINGLE TIME I had to do it because a friggin safety was malfunctioning and wouldn't allow the key to start it. You are right I have already made up my mind. You're free to do the same.
/ Seat switch bypass #57
I don't have an issue with the switch. If I did, and it was causing me anguish, I would be looking at other options I suppose.
I do take risks. I drive over the speed limit from time to time, have, at times, had that second glass of wine at dinner out and enjoy a good cigar. Would I take the seat switch out? Probably not because I'm always by myself in the middle of nowhere when I'm on my tractor.
/ Seat switch bypass #59
Try picking up something from ground level with pallet forks with the seat safety being operational. Assuming a tractor already has a safety to prevent being started from the ground (clutch or neutral safety) what good is a seat safety going to do?
Harlo HP6500 (A60462)
203201 (A60429)
203201 (A60429)
1995 Stoughton Enclosed Dry Van Trailer, VIN # 1DW1A5323SS900663 (A57453)
1995 Stoughton...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
SANY SY35U EXCAVATOR (A59823)
SANY SY35U...
Ford 8210 (A60462)
Ford 8210 (A60462)
