SCUT Mowing - Ground Speed?
/ SCUT Mowing - Ground Speed? #41
Here's a question for ZTR fans who get their mowing done quicker. The ZTR's advantages for trimming around obstacles are obvious. But if you figure you're going faster over open ground too, either the quality of cut is being sacrificed by going so fast or your mowing deck runs at much higher rpm's to keep up with the higher ground speed. Or maybe you mow more often so the grass isn't so heavy. I honestly want to know. At my place, the grass is heavy and going too fast means either disharge clumping or poor cut quality.
Good question!!!! I've asked it before on TBN and never got what I would call a verifiable answer. We'll see what happens here. :)
/ SCUT Mowing - Ground Speed? #42
I am beginning to think people lie as much about their mowing speed as their mpg and their fish size. :laughing:
/ SCUT Mowing - Ground Speed? #43
I can comment on the 2 zero turns I have owned.
My lawn grows thick and fast. Generally mow about once per week.
My previous zero turn was a Hustler FasTrac 21 HP 54" deck. Top speed was 8 MPH. It would mow fine up to top speed at about any deck height setting. The reason I upsized from that mower was power. Had trouble mowing at full speed in our thick, fast growing grass it would run out of power, forcing me to slow down.
My current zero turn is a Hustler Super Z. 35hp Kawaski with a 72" deck. Top speed 14 MPH.
This mower is awesome, but cut quality at higher speeds depends a lot on cutting height with the VX 4 deck.
If the deck is set to 3+ in cut height I need to slow down to get a quality cut.
If I have my deck set at 2 1/2" or less it will cut great at all speeds.
I have my deck set at 2 1/2" on my Super Z and get a good cut all the way to the top mowing speed of 14 MPH.
/ SCUT Mowing - Ground Speed? #44
I mow 2.5 acres. Have a JD 2305 with 60” deck, FEL and such. Don’t have a backhoe - but it would be nice 1x year. Bought a jd z-turn a couple of years ago and it runs circles around the tractor; better cut, too. I’d recommend sacrificing a BH for a ztr all day long. I haven’t used the 60” deck since; leaves the tractor in better position to be useful for other chores.
/ SCUT Mowing - Ground Speed? #45
It's in the top three anyway. :D
/ SCUT Mowing - Ground Speed? #46
Would you care to give your reason why?
/ SCUT Mowing - Ground Speed? #47
Well, having asked the question, I also felt the need to dig a little deeper myself. My 54" Kubota BX deck spins the blades at about 15,000 fpm. The 52-54" ZTR's I looked up online were showing comparable blade speeds of 18,000 - 19,000 fpm, so there is a 20-25% difference. Should mean better cut and discharge performance and also able to cover ground faster. How much faster? Side by side on the same ground, whaddya think? I'd guess maybe 20-30%, wouldn't expect it to be twice as fast.
/ SCUT Mowing - Ground Speed? #48
Bingo! Blade tip speed is the key. Commercial ZTR's have the fastest tip speeds you can buy. This is why they have superior cut performance, even at higher ground speed.
/ SCUT Mowing - Ground Speed? #49
I don't see cutter vs ZTR being an apples to apples comparison. Each has it's own place, that is why I have both. You have to look at the height of the deck & blades, height & type of grass, etc. I cut with the ZTR at 3.5", my cutter is set at 6". Cutting the 12" high yard is no problem with the ZTR and it runs circles around the tractor, cutting 24" pasture grass is a different matter. The mass of the cutter blade, even at a slower speed, will help in the tall thick grass that would prevent a ZTR from giving an acceptable cut.
Now let's throw in the diesel vs gas argument. :stirthepot: That could be better than gear vs HST.
/ SCUT Mowing - Ground Speed? #50
The 60" woods Brushbull has a speed of around 14,000 rpms. My Zero turn is around 18,000. But you also have finish blades on the zero turn. The BH has thicker blades and will cut up to 1.5" diameter. So it is difficult to compare cut quality.
I have found that it is not possible to run full speed on my 42" residential grade Exmark. It will run at 7.5 mph but will beat you to death as there is no suspension. My guess is that a tractor at 3.5-4 mph with a 60-72" deck will take just as long or perhaps a little longer to cut.
A couple of benefits to the tractor in my particular situation is the following; Tractor is a muti-purpose tool if you have the FEL. You don't have to stay on top of all of the grass year round. If you let it get too long you lose the time saving benefit of the ZTR.
On the other hand many ZTR's are cheaper, easier to transport, fit in a garage and have a beautiful finish cut. In a perfect world we would all have both.
/ SCUT Mowing - Ground Speed? #51
To clarify, the BX has a mid-mount finish mower deck, not a brush cutter, so my comparison was SCUT mower deck to ZTR mower deck. Used a 3 pt. separate brush cutter for rough stuff... totally different animal.
/ SCUT Mowing - Ground Speed? #52
This was an easy decision for me. I mow about an acre with lots of edges and tight turns. I use a Z turn for mowing and my BX25D for everything else. A MMM would be in the way for anything but mowing on my property and I surely don't want to be taking it on/off. My Z-turn retired my JD garden tractor because of its speed and maneuverability.
Seems to me that your only decision is whether to get a BH or not and keep your Z turn. I love my BH... I maybe don't use it enough to justify the extra dollars spent after 4+ years but I plan to keep it for my lifetime so I don't fret about the ROI. Every time you want to dig a hole for planting, or trench a bit, or pull something out, you will love not having to use a pick/shovel or hassle with a rental. Just depends how much landscaping you have in front of you. Me, I have a lot including re-landscaping. Building/rebuilding terraces is a major part of it.
/ SCUT Mowing - Ground Speed? #53
Yes it makes a BIG difference.
I have several mowers.
Landpride AT 2572 (72" rear finish mower) Blade tip speed 15,500 FPM
First Choice GM 35-84 (84" rear finish mower) Blade tip speed 15,300 FPM
Hustler Super Z commercial grade zero turn (72" VX4 deck ) Blade tip speed 18,530 FPM
I can mow at MUCH higher speeds with my zero turn and still get a good cut.
That plus my zero turn with suspension seat, flex forks and 7-8 PSI tire pressure rides a lot a better than my tractor with r-4"s and 35 PSI front and 15 PSI loaded rear tires mowing at higher speeds.
And the maneuverability difference is massive.
Combine all of the above and the zero turn will out mow my tractor by a HUGE amount.
/ SCUT Mowing - Ground Speed? #54
My 60” mower is not a drive-over deck, so it takes a little effort to install/remove. And between mowings, there’s other stuff to do where the box blade or FEL or tiller are needed, so keeping the deck installed is not desirable. I had a 54” deck Craftsman garden tractor for the mowing and when that finally died, decided to get the ztr and retire the 2305 from mowing. 54”
ztr is faster (30% or more) and cuts better than the 2305 deck, maybe due to lay of land, slopes or frequent obstacles/trees. I still have the deck for backup, but haven’t installed it last two seasons.
If I didn’t have the ztr, I’d opt for a used garden tractor to mow and keep the 2305 running other specialized chores.
/ SCUT Mowing - Ground Speed? #55
Sounds like the ground speed difference is directly related to blade speed. It's the only reason I can think of too. Was just curious to hear other's thoughts.
/ SCUT Mowing - Ground Speed? #56
Just going by what I see around here, properties mowed with a ZTR tend to be finished lawns that are pretty smooth. The places that are former pastures and cornfields and remain fairly rough, like my place, are more typically mowed with some kind of tractor. My neighbors mow their smooth lawns on ZTR's, going twice as fast as I can get over the ruts and divots on my place with the tractor. All the neighbors see is that they are going twice as fast as me, but that's not the whole picture.
A high-end ZTR with either suspension seat or full suspension would make a difference also in how much abuse the operator experiences.
I've learned something from this discussion. Maybe I'm just easily entertained, but mowing my 6 acres regularly with the SCUT over the last 10 years has been enjoyable seat time for me. But if I didn't have the time or inclination for doing it, or did it for a living, I'd be looking for a top grade ZTR as soon as the place got smoothed out some more.
/ SCUT Mowing - Ground Speed? #57
I agree. Takes me 8 hours to mow everything with my JD2210. By the end of Summer it's wearing a little thin. But generally I don't mind.
In my World, if I only had one machine, it would most definitely be a SCUT/CUT. Wouldn't even consider a ZTR. If I had multiple machines and money, ZTR and SCUT/CUT (depending on task list).
For private use I consider a ZTR a luxury. I feel that way because it only does one task. Hard for me to justify a $10K ZTR that sits 7 months out of the year.
I see more discussion here about ZTR owners debating trading for a SCUT than I do SCUT owners debating trading for a ZTR. :)
/ SCUT Mowing - Ground Speed? #58
My Land Pride FDR2572 72" 3-point finish mower is 18,130 FPM tip speed. You claim your same model is 15,500 FPM?
https://www.landpride.com/ari/attach/lp/public/features/310-262f.pdf
/ SCUT Mowing - Ground Speed? #59
/ SCUT Mowing - Ground Speed? #60
Isn't that odd. The Land Pride website I linked to above clearly speaks differently to the blade tip speed.
2018 FREIGHTLINER CASCADIA 125 6X4 T/S SLEEPER TRUCK TRACTOR (A67147)
2018 FREIGHTLINER...
2022 EZ-GO ELITE...
JOHN DEERE 7200R TRACTOR (A64278)
JOHN DEERE 7200R...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
213085 (A64276)
213085 (A64276)
LEEBOY SUPER 400 DOUBLE DRUM ROLLER (A65053)
LEEBOY SUPER 400...
