Screw drive garden tractor
/ Screw drive garden tractor #23
Hey Rednic79, will video 4 be coming anytime soon? I enjoyed the heck out of the first 3 so far!
/ Screw drive garden tractor #25
Looks like Surplus Center sells the ZTR transaxles for $460-600 per pair (Surplus Center)
Aaron Z
Don't need a pair. Left and right drives are independant.
That sounds like a pair to me. A pair of shoes is one right and one left.
Here is a pair of ZTR transaxles.
/ Screw drive garden tractor #26
For pontoons I wonder if you could just take some culvert (the stuff that looks like a screw) and weld some ends on it to make it float.
/ Screw drive garden tractor #27
I don't think culverts are actually "screws." I believe they are just convoluted, so they would just spin with no forward propulsion.
/ Screw drive garden tractor #28
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=410360"/>
All the ones I had seen 'till now were one housing. The two separate housings would be better, as you could turn them to have the output shafts inline with the screws. Then just a few sprockets to couple the output to the screws.
/ Screw drive garden tractor #29
There are three levels of those transaxles (from lowest to highest quality):
1. One housing for both sides
2. Separate housings
3. Separate pumps and wheel motors
Aaron Z
/ Screw drive garden tractor #30
Not all culverts have a screw pattern, but I've seen some that do.
Example:
/ Screw drive garden tractor #31
Some are made this way.
Too slow again, jjsjeff posted while I was looking at google images.
/ Screw drive garden tractor #32
Example:
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=410380"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=410383"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=410384"/>
Well I stand corrected... in that case, those look like they would work nicely.
/ Screw drive garden tractor #34
Awesome!! :thumbsup:
This project is soooo fun to watch!
/ Screw drive garden tractor #36
It sure looks like that sucked. Would it work to slice the ring in multiple pieces, tacking them on in that spiral shape?
well...the only thing is that they need to be 'twisted' not just angled, so without the leverage of the larger piece it's hard to twist. when I get to the end of one ring, I can barley twist it right until I weld the next ring to it for leverage.
/ Screw drive garden tractor #38
OK, gotcha. So, another question - could you weld the rings together first, or would it just take way too much to stretch it all apart in one piece?
/ Screw drive garden tractor #39
Nice job!
A thought on the calculation for the ring... I think you would want to use the circumference of the tube as a starting point. Then add the spacing that you want, which gives you your new circumference. That would come out to about 11.3" I.d.
I'm not sure if that's right either, but it's the formula I came up with a couple days ago when I was thinking about this.
/ Screw drive garden tractor #40
I'm guessing they wouldn't work very well for more than one reason. The most serious is ou'd need to find righ and left hand culverts. To travel, the pontoons need to rotate in opposite directions. Otherwise, the tractor will travel sideways.
2024 JOHN DEERE 250P EXCAVATOR (A60429)
2024 JOHN DEERE...
(16) WOOD PALLETS (A60432)
(16) WOOD PALLETS...
2012 FREIGHTLINER CL120 CONVERTED TANDEM AXLE GLIDER DUMP TRUCK (A59905)
2012 FREIGHTLINER...
2005 John Deere 7320 (A60462)
2005 John Deere...
SCAN TO RECEIVE TEXT UPDATES (A60430)
SCAN TO RECEIVE...
2025 JMR 40in Single Cylinder Brush Grapple Mini Skid Steer Attachment (A59228)
2025 JMR 40in...
