RTV - X1100C
   / RTV - X1100C #101
Thank you. I’ll also try raising/lowering the blower.
   / RTV - X1100C #103
I cleared snow with the new RTV-X1100C "for real" (outside of practicing operating the unit) for the first time this morning. Super impressed with the power of the blower, overall RTV power, stability, & traction. I have the HD worksite tires, and didn't carry any extra weight in the bed. The cab is great: I had to lower the heat because I was getting too warm. I turned on the AC because the windshield was fogging up and it worked like a charm. The windshield wiper came in handy.
I was getting frustrated with shifting for the first 30 minutes because some areas that I clear require a lot of backing up / go forward maneuvers, and it felt like the transmission more often than not would not smoothly shift into reverse then back into "L". I tried two mitigation techniques: (1) with my foot on the brake, "blip" the throttle pedal briefly, then attempt to shift. This helped somewhat but annoyed me every time I had to do it. (2) swampy6 mentioned that changing the height of the front implement (in his case the Boss V-Plow) helped. I tried this with my blower, and I was surprised that it did sometimes help.
Then for some reason things started getting better: I think the main change was me having a lighter touch with the shift lever. If I encountered any resistance, I jiggled the shift lever slightly, then tried again, lightly. Things just seemed to work better. I only had to use the floor throttle "blip" a couple of times in the second half of my snow clearing. My frustration level dropped, and I began to enjoy the job.
It is odd to me that shifting difficulty seems to be a widespread issue for people, and Kubota hasn't done anything to address the issue. But I am heartened by the fact that maybe me adapting to the quirks may be enough to let me enjoy this otherwise GREAT machine.
   / RTV - X1100C #104
Once you get use to taking your time and if you keep brake pedal depressed once stopped shift issue no biggie for me anymore. I can relate to once you have presure against plow or blower raising unit does relieve that presure at times. Also I drove a Mack Tractor with a 5 speed for years you learn to take your time shifting. LOL. congrats and enjoy your machine.
   / RTV - X1100C #105
I find the RTV-X1100C much more capable - more power even with the two speeds - more comfortable - better heater that can get too hot - smoother ride with IRS
Last week we had 15" of snow and had no problem pushing it around
Headed out tomorrow to look at a 2021 Kubota 1100c cab model. Here are my options (front/rear led work lights,2 side mirrors, front/rear cv joint guards, tail lamp guard kit,BOSS V plow VXT with side markers and skid shoes.Price out the door $26,418.Is this a fair price ??
   / RTV - X1100C #106
How much is the V plow ?... I Have a 1100C with a straight blade..Wish it was 7' as it is just a bit small at 5'. I made some angle adjustments to the blade and it appears to push snow easier now. Not great..but sure beats the shovel.
   / RTV - X1100C #107
Purchased the 1100c model this morning after some discussion with my dealer I canned the Boss v-plow $4,695 and went with the Kubota commercial grade 72 inch straight plow #V5060 for $3950.Suited me needs better.
   / RTV - X1100C #109
   / RTV - X1100C #110
Keep us posted on how it compares to the 900, suspension, two speeds etc.
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
30" X 20" X 72" METAL SHELF (A52708)
30" X 20" X 72"...
ISUZU DUMP (A56858)
ISUZU DUMP (A56858)
2016 WINNEBAGO SCORPION 4014 5TH WHEEL CAMPER (A58214)
2016 WINNEBAGO...
LOT: (3) Adjustable Steel Racking Sections, 9' W x 24" D x 56" H (CONTENTS NOT INCLUDED - DELAYED (A59076)
LOT: (3)...
