Rounded off drain plug
/ Rounded off drain plug #1,081
Nah, you all have missed the challenge.
Grab your Holehawg, drill an new hole and let out that old well used oil.
Then weld a new threaded flange with your nice new TIG welder and fit the appropriate plug.
There, you now have added two very necessary tools to your shop and saved a tractor!
OK, tractor saved and pocketbook now depleted and 2 new tools that will someday again serve U.
We all need new tools!
/ Rounded off drain plug #1,082
Sometimes I think why even bother with this thread. It doesn 't seem like there is any progress. And then there is a post like this that makes me laugh. Some of you guys have a really neat sense of humor.
I hope /pine reads this^^ :D
/ Rounded off drain plug #1,084
Now this thread is really going downhill. Next Geoduck will be asking if the refrigerator light really does shut off!
/ Rounded off drain plug #1,085
Well actually it is burned out but the bulb is stuck and seems to be rounded off. How do I get it unstuck?
/ Rounded off drain plug #1,086
A good quality pipe wrench.
Bruce
/ Rounded off drain plug #1,087
/ Rounded off drain plug #1,088
Weld a good quality pipe wrench to it. :silly:
/ Rounded off drain plug #1,090
Why is this so tempting to me? Finally put one of them cheap pipe wrenches to use. If only i had the equipment.:D
Lets not get ahead of ourselves now, we have to discuss the plan some more. There may be a better tool for the job. :D
Hammer an undersized socket on, weld it. Attach and weld breaker bar to socket. Weld pipe wrench to breaker bar. Then, finally, turn the tractor to loosen?
/ Rounded off drain plug #1,093
Close enough to a Rube Goldberg solution that I'll allow it... as long as at least one of the components is made by ACME.
/ Rounded off drain plug #1,094
/ Rounded off drain plug #1,095
Run cord from across the room for new light inside. If door doesn't shut, drill hole. Use outside flood light with motion detector on it. We don't want it to stay on all the time and heat the beer.
/ Rounded off drain plug #1,096
My wife wants to know why I have to check the internet 3 times a day. I HAVE TO SEE ABOUT THE DRAIN PLUG!
/ Rounded off drain plug #1,097
This is the easiest way...
1) remove exhaust pipe & steering wheel
2) Chock back wheels, put in neutral
3) drain gas & coolant
4) remove trans fill plug
5) have a keg party inviting 40 strong guys
6) after an hour or so...say "I bet we could flip that tractor upside down, up and backwards".
7) after draining, flip it back up.
/ Rounded off drain plug #1,098
Kando actually got it removed by the time we hit page three; but found the thread so entertaining that he didn't want to tell us.
/ Rounded off drain plug #1,099
You forgot to work a vice in there :laughing:
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
2004 VOLVO VHD TRI/A CEMENT MIXER TRUCK (A59911)
2004 VOLVO VHD...
2019 WABASH DVLSHPC 53X102 T/A DRY VAN TRAILER (A59912)
2019 WABASH...
2025 Wolverine MSG-11-44W 44in Stump Grapple Mini Skid Steer Attachment (A61572)
2025 Wolverine...
2006 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-250...
2012 POLAR TANK TRAILER (A63569)
2012 POLAR TANK...
