Rounded off drain plug
/ Rounded off drain plug #1,041
When the pipe wrench fails ....
Perhaps this has already been mentioned
/ Rounded off drain plug #1,042
This is the longest thread I have ever encountered without a conclusion. And over a pipe plug! :shocked:
Obviously it's more important to us than to Kando that the drain plug gets removed. Or perhaps some of us just have too much time on our hands. :eek:
Yes, that was suggested earlier in the year. I don't understand why you didn't reperuse 1048 posts before suggesting it. :D
/ Rounded off drain plug #1,043
Delete
/ Rounded off drain plug #1,044
What I was told over 60 years ago in high school shop class, was with the pressure point farther up the moveable jaw, it is more likley to break the jaw:
That is also what I was taught.
I work 2nd shift 7 days a week, it's cold outside and I'd have to bring the tractor out of the barn to have a suitable workspace with enough light to see.:thumbsup:
Beyond that I've been tinkering on the 5000 i got. Changed the temp sender, coolant, engine and trans oil (water in the trans, eck) and next is replacing the exhaust manifold and muffler.
/ Rounded off drain plug #1,047
Again, we need a tongue in cheek icon.. (and maybe a slipping pipe wrench icon)
/ Rounded off drain plug #1,048
Sounds like the 5000 needs your attention anyway. In just 10 days the days start getting longer anyway. :)
/ Rounded off drain plug #1,049
Another diagram:
Bruce
/ Rounded off drain plug #1,050
Nice. I love those old Fords and am still toying with the idea of bringing my father's old gas 4400 (industrial) home. My brother keeps saying that we should sell it; running, we'd be lucky to get $4000 out of it. In current condition, it hasn't even been started in 4 years we'd be lucky to get a grand for it.
Either way it's worth more than that to keep around for the occasional use when I need a bigger tractor; maybe I'll put the cab on and keep it for plowing.
/ Rounded off drain plug #1,051
My vote is to have a mechanic or plumber acquaintance stop out and remove it. Until you've done it, the whole process is foreign and just invites you to dig a deeper hole. We've all been there and once you watch it being done you'll be a pro.
/ Rounded off drain plug #1,052
View attachment 582643 View attachment 582644
True. But pulling backward as in the 2nd pic tends to open the jaw slightly as the wrench flexes causing it to slip easier, rounding the head at a lower delivered torque.
/ Rounded off drain plug #1,053
/ Rounded off drain plug #1,055
Held like the first picture in your right hand it’s easily adjustable. Held like the second picture it’s kinda clunky. IMG_0876.JPGIMG_0877.JPG
/ Rounded off drain plug #1,057
Digital gauges and digital calipers especially ones that see infrequent use are always dead when you need them.
/ Rounded off drain plug #1,058
If this plug does end up getting welded out what kind of welder should we use. I’d probably use my mig so what shielding gas would be optional and should we use flux core. After all these decisions are made and assuming we have decided in the type of plug which sealant is best?
/ Rounded off drain plug #1,060
How about tire pressure gauges? Stick, dial, digital, oh boy!
You just dont seem to be properly prepared to do any repair work. Tools, shop, lighting, etc...Have you considered a nice apartment downtown? :p
RoGator RG1300C (A63688)
RoGator RG1300C...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
2007 MACK CHN613 6X4 T/A DAY CAB TRUCK TRACTOR (A59909)
2007 MACK CHN613...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A63688)
2022 Schulte...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
2012 LincolnMKX Hybird Sedan (A61574)
2012 LincolnMKX...
