Rounded off drain plug
/ Rounded off drain plug #821
/ Rounded off drain plug #822
An acquaintance seen my 24" & 36" pipe wrenches laying on the bench this summer and asked what I used them for. I said there is always something around here that needs bent a little or straightened out.
He had no idea what I was talking about.
/ Rounded off drain plug #823
My first post regarding this thread . I just hope Kando wears correct gloves , eye protection , has proper lighting.... !
And a cup :silly:
/ Rounded off drain plug #824
Of course.... a pipe wrench should ONLY be used for pipe?
Silly me...for thinking there might be other applications.
That's OK Mate, I understand that "when the only thing you have is a hammer, everything looks like a nail."
/ Rounded off drain plug #825
Why so much angst against using a pipe wrench?
It is a PIPE fitting.
Pipe wrenches are MADE to grip on something round.
The harder you pull, the harder they bite. The QUALITY part comes down to the jaws. Junk one's round jaws off.
This ISNT about having a hammer and everything looking like a nail. A pipe wrench IS a correct tool for this job
/ Rounded off drain plug #826
Yup.... but some do not understand!
/ Rounded off drain plug #827
But he already tried a pipe wrench and it didn't work. :(
/ Rounded off drain plug #828
I don't think he tried it with the gusto we now require of him. Using the right pipe wrench with confidence and force, that plug would have popped right out. I suspect it was a light duty wrench and a fleeting effort.
Kando sounds like he's now on right track and I'll bet that plug's days are numbered.
/ Rounded off drain plug #829
.... Kandi sounds like he's now on right track and I'll bet that plug's days are numbered.
But this thread will live on :)
/ Rounded off drain plug #830
I certainly hope so... we still need 165 more posts before it hits 1000.
With all due respect, a square plug is not round. And while this may have had the corners rounded off it still doesn't fit that description. However, if going that route bigger isn't always better. Also, LouNY made a very good suggestion about 150 posts ago.
/ Rounded off drain plug #831
Anybody who has ever used a QUALITY pipe wrench should understand that a pipe wrench is the best tool for this task, particularly since the head of the plug is now totally buggered up.
/ Rounded off drain plug #832
Exactly. I have used my pipe wrench as a hammer before, but I maybe should borrow my neighbors pipe wrench next time so I do not mess mine up.
:rotfl: :rotfl: :rotfl:
This might make a good hammer
36" External Pipe Wrench
/ Rounded off drain plug #833
Other than a welder what approach would you suggest? While I feel fairly certain a pair of Knipex pliers which have much better teeth than cheaper pliers would work a quality pipe wrench is the right tool for the job.
/ Rounded off drain plug #834
I have suggested many times that he get somebody more knowledgeable, as it would have eased(edit)perceived(end edit) his angst. ;)
For whatever reason, his attempts with a pipe wrench only made matters worse
/ Rounded off drain plug #835
I have suggested many times that he get somebody more knowledgeable, as it would have eased his angst.
“Perceived” angst.
/ Rounded off drain plug #837
/ Rounded off drain plug #838
Ok, I've been a fan of Knipex already but that video is freaking amazing. Menards carries these in stock, along with several other Knipex pliers in case someone wants to see them in person.
Ok, well this thread had done one thing. It has made me order a set of these pliers.
/ Rounded off drain plug #839
Hard to believe that Snapon actually sells that wrench for $285 when it is $135.83 on Amazon, and even less elsewhere.
/ Rounded off drain plug #840
Yep, and that's the great thing about this (and other TBN threads)... others can learn about other tools. That Knipex looks interesting.
I tried to keep my posts regarding fried1765's repeated calls for using a pipe wrench to a light-hearted banter. I guess we won't know until Kando finally gets around to doing it.
2014 Ford F-150 4x4 Ext Cab Pickup Truck (A64194)
2014 Ford F-150...
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
2007 MACK CHN613 6X4 T/A DAY CAB TRUCK TRACTOR (A59909)
2007 MACK CHN613...
2015 Kubota RTVX1100C (A62177)
2015 Kubota...
2024 DEVELON DL250-7 WHEEL LOADER (A63276)
2024 DEVELON...
JOHN DEERE HX 14' ROTARY MOWER (A63291)
JOHN DEERE HX 14'...
