Rounded off drain plug
/ Rounded off drain plug #343
Yes, but we've covered that he could vacuum most of it out. Or turn the tractor over and drain it.
neither method should be used, since you'll wind up with metal particles, and worn out oil left in the engine.. and flipping the tractor over is the worst of those!..
So what - it's done all the time on cars. Your filter should take care of the metal and a little old oil is not harmful. And I thought most people would understand the sarcasm in "turn the tractor over".
Did anyone ever ask the op which direction he was turning the wrench?
nope, everyone just assumed...
It took 35 pages for someone to think of that one!
Taken care of WAY back in posts 93 & 94 (and remember referring to "pages" is meaningless, I'm only on page 9):
Are you certain you are turning it in the correct direction? :confused2:
That I am
Righty tighty, lefty loosey.
That's part of the problem with these long threads, posters either don't read or don't remember and keep offering the same solution.
/ Rounded off drain plug #344
things are done on cars all the time that never should be done.. and YES, people may either not read all the pages, and remember the replies on long threads!..
/ Rounded off drain plug #345
Yikes, this is still alive?!
So if he's not going to turn the 'tractor' upside down, why not lay it over on it's side to gain access. Don't forget to ask it first which side it prefers to lie on.
OR, grind what's left of the whatever type headed plug, then center punch it and then drill it with a close to the original thread diameter bit and let the 'oil' out. Then easy out the remaining carcass of the original plug and insert a new plug, with a head that the OP can put a wrench on to remove for the next 1000 year oil change, whether it needs one or not. Job done, throw money!:applause:
/ Rounded off drain plug #346
It would be much easier to remove the offending cross member and modify it so that it can be bolted on and taken off the next time that this occurs.
/ Rounded off drain plug #347
I am afraid the OP is sorry he ever asked for help at this point.
I had to do a timing chain on a ford 5.4 3 valve engine over the weekend. I thought I was going to have the same issue with that drain plug. But thankfully a 6pt socket, pull handle and a good shop hammer broke it loose. :)
Last week we picked up the 2010 F150 5.4 with 206,000 miles and no history. Very quiet on start up and afterwards.
There are issues more complex and it sounds like you found one.
/ Rounded off drain plug #348
My Dad bought this one, 2007 f150 from my nephew. He knew it had the timing chain issue. He also knows his son, me, will do anything he asks. Somebody over tighten the drain plug and put the wrong oil filter on the truck. The Oil pump replacement was the worst part of the job. But, it's running again and Dad thinks he won the lottery!! :thumbsup:
/ Rounded off drain plug #349
'Easier', has nothing to do with this thread.:confused3:
If I was the OP I would have left this thread a long time ago....
/ Rounded off drain plug #350
Apparently he did. His last post was almost a month ago.(5/21)
/ Rounded off drain plug #351
It seems the pallet thread waited a lot longer than that for old sparc in hopes that he would return. We are just getting started.
As a famous person once said —— Now this is not the end. It is not even the beginning of the end. But it is, perhaps, the end of the beginning.
/ Rounded off drain plug #354
This thread should not be confused by logical posts :whistleblower:
/ Rounded off drain plug #355
OK. Can't turn the plug?
Then just hold the plug still and turn the tractor.
Bruce
/ Rounded off drain plug #356
This thread has turned into another "geezer pacifier"...
You do realize the owners of this site have a Swiss bank account that gets regular deposits by the wives of several TBN regulars for payment of day/night care services don't you??
/ Rounded off drain plug #357
I can't think of any better suggestions than those already offered, however.....
Something I should clarify, the plug isn't seized, it was over-tightened, massively. Malicious family members. Shed has been chained and locked to prevent further issue there. Head of the plug was stripped a bit as a result of the over-tightening and further torn up from me trying to remove it.
has me a little puzzled.
If someone wanted to sabotage the tractor by messing around with drain plugs, why over-tighten a drain plug that hardly ever needs to be removed? Surely, it would make more sense to sabotage the crankcase, or some other, drain-plug?
It might be prudent at this time to point out to those a bit less experienced with drain plugs that, if one removed the plug while the engine was hot, it is imperative that the engine be allowed to cool completely before replacing the drain plug. This applies mainly to tapered plugs.
When removing the plug from the hot engine, both the hole and the plug are larger than they would be when everything is cool. The removed plug cools quite quickly and shrinks in the process. The hole in the hot engine stays enlarged. This allows the cold, smaller plug to be driven deeper into the larger hole in the hot engine. When their temperatures equalise, the connection between the plug and the engine will be so tight that it can make removal of the plug extremely difficult.
I wonder if this might have happened with Kando's tractor.
Ken
/ Rounded off drain plug #358
Ken
If the engine must be cooled completely before the plug is replaced, how do lube shops get by changing the oil in a hot car every few minutes?
/ Rounded off drain plug #359
It all depends on whether the plug is tapered or has parallel sides. To the best of my knowledge, most modern cars have drain plugs with straight threads, not tapered, and rely on a washer/gasket to ensure the seal.
In the days when I used to service my own cars (circa 1970's and '80's), the drain plugs tended to be tapered. They also had 'female' square heads, into which one fitted a 'male' square wrench - a lot like a grub screw and allen key arrangement, but square. Some cars had straight plugs with gaskets for the sump and tapered plugs with square holes for the gearbox and differential. large202908.jpgDrain plug key.jpg
The plug on Kando's tractor appears to be tapered.
I have never taken my car to a quick-lube place, so I can't comment on how they do things. Might they vacuum the oil out?
Another option, other than letting the engine cool, is to insert the tapered plug just tight enough to allow it to be in contact with the sump to allow heat to transfer from the sump to the plug. Once the plug has reached the same temperature as the sump, torque the plug to specs.
Do most tractor owners tend to drain their oils while the engine is hot or cold?
/ Rounded off drain plug #360
In the days when I used to service my own cars (circa 1970's and '80's), the drain plugs tended to be tapered. They also had 'female' square heads, into which one fitted a 'male' square wrench - a lot like a grub screw and allen key arrangement, but square. Some cars had straight plugs with gaskets for the sump and tapered plugs with square holes for the gearbox and differential.View attachment 558711View attachment 558714
My guess is that most tractor owners in the US change oil when it's hot and the hotter the better.
