Rounded off drain plug
/ Rounded off drain plug #82
rlgustafson and downslope, Those are power adjust wheels but nothing like the originals and not interchangeable.
/ Rounded off drain plug #83
So what do you think these rims would be used for? Obviously they would require an interchangeable, compatible center section. Maybe they're meant as replacements for the later 3 cylinder Ford tractors?
/ Rounded off drain plug #84
Yes they are a much more common style. Here's a video showing the old Ford style that I was referring to.
Ford 96 spin out rims - YouTube
I stand corrected. When looking for images or videos of these old Ford spinouts, I found a reference that Walt's Tractor sells some of these old style replacement rims.
/ Rounded off drain plug #85
For those with odd wheels and a fat wallet, Unverferth can cut the centers out of wheels and weld in one of their centers with the correct bolt pattern and center hole that you want. I had it done once and they do an absolutely perfect job. Flawless workmanship.
I had 30" wheel centers with a Ford bolt pattern and I wanted the standard 8 bolt on an 8" center with a 6" center hole so I could use on a different tractor. No problem.
/ Rounded off drain plug #86
So..oo... What has happened with the drain plug?
Anything?
/ Rounded off drain plug #88
The world famous drain plug!
Anything?
Nothing yet, picking at it myself. Down with a sinus bug now, bit me hard yesterday. New tube for the tire arrived so looking into getting that switched out.
/ Rounded off drain plug #92
Since this is an advice seeking thread, my observation would be first things first before you snap off that remaining plug stub while not focused and have a real problem a few bucks won't fix. Right now it's just chuckles over beer but things can go south.
/ Rounded off drain plug #93
Are you certain you are turning it in the correct direction? :confused2:
/ Rounded off drain plug #95
Pretty sure I have NEVER seen a left-hand thread drain plug!
Gave it another go with a decent pipe wrench, got a good hold on the threads and thought I had managed to get it. Just started stripping down the threads.
/ Rounded off drain plug #97
If you have a propane torch heat around it a bit. Grab it again and hit the wrench with hand. Rapid bumps work best. Or a hammer if you have room.
If that doesn't work getting a nut welded to it is your best bet.
/ Rounded off drain plug #98
It’d be messy but, can’t you just remove the entire pan? Then you’d at least have good access to work on it.
It壇 be messy but, can稚 you just remove the entire pan? Then you壇 at least have good access to work on it.
It's the transmission drain plug, pretty sure I would have to split the tractor.
2015 John Deere 210G Hydraulic Excavator (A61567)
2015 John Deere...
2021 Big Tex Trailer Trailer, VIN # 16V3F4826M6084230 (A61165)
2021 Big Tex...
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
2019 Freightliner M2 106 26ft. Box Truck (A61568)
2019 Freightliner...
2008 Freightliner B2 Bus, VIN # 4UZABRDJ98CZ17952 (A61165)
2008 Freightliner...
1995 GMC TOPKICK FUEL INJECTION CHASSIS TRUCK (A62130)
1995 GMC TOPKICK...
