Rounded off drain plug
/ Rounded off drain plug #101
Gave it another go with a decent pipe wrench, got a good hold on the threads and thought I had managed to get it. Just started stripping down the threads.
As it starts slipping/stripping on the plug you may have to make minute adjustments closing the wrench down to maintain a grip.
All pipe plugs are not the same, some are all solid, some are hollow in the threaded portion and others hollow all the way thru. If you knew for sure it was hollow you could cut the head off and then collapse the threads with a chisel.
If all fails you could try to get a hold of one of the bolt extractor tools mentioned earlier, and if not enough room to get a proper wrench on it, then turn it with a pipe wrench.
/ Rounded off drain plug #102
At some point you are probably going to have to take that crosspiece off, or bring it to somebody with more experience/the proper tools. The worse you make it, the more time/money it's going to take to fix it.
If you opt for the former, once the crossmember is out of the way you will probably be able to drive a smaller socket over it and spin it out.
Having said that, if you want to keep trying I would dispense with the pipe wrench and get a good set of curved jaw vise grips, and fix up a cheater bar on that.
/ Rounded off drain plug #103
When things are stuck I revert to using one of two techniques, and both if possible. Heat and impact. In my experience a steady pull, regardless of wrench type is generally not the solution. You could try putting a good pressure on it with a pipe wrench and simultaneously beating on the wrench with s big hammer. In your case I would beat close to the plug to transfer as much impact to the plug as possible.
A better solution would have a welder run by and weld on a nut. Then use heat and an impact to rock the plug back and forth until it gives. If I go with brute force I usually break something and my problem gets a whole bunch worse.
/ Rounded off drain plug #104
Try a centerpunch and heavy hammer. Hit it GOOD from 4 directions, about 30-45 degrees upward, several times.
(I'd use my air hammer and a blunt chisel. Don't want to cut it off, just jar it loose.)
Bruce
/ Rounded off drain plug #105
Are you certain you are turning it in the correct direction? :confused2:
For some reason I always get disoriented when it comes to lefty loosey - righty tightly when I am laying on my back under an engine. So I have to mimic the hand motions of opening an upside down pickle jar before I know that I am correct. Crazy but true, I have done it hundreds of times.
:cuckooclock: :hypnodisk: :hypnodisk: :cuckooclock:
/ Rounded off drain plug #106
Many years ago, but when I was still old enough to know better, I had my rightey-tightey, lefty-loosey thing down pat and muscled all I had to get off the front lug nut off on an F600 Ford Farm truck. Only when I finally got it off did I wonder what the "L" was on the face of the lug nut. It retrospect, it should have stood for "loser" because I sure felt like one. Took all day to replace the stud on the truck and money I didn't have.
/ Rounded off drain plug #107
Agreed; the jaws need to be closer together and the plug farther on the wrench jaws.
/ Rounded off drain plug #108
107 posts. This has GOT to be the most stubborn drain plug in the history of machinery!
/ Rounded off drain plug #109
It's the transmission drain plug, pretty sure I would have to split the tractor.
Now were talking! :D :D
I hope this thread doesn't end up like the one about adding a block heater which resulted in a split and a rebuild.
/ Rounded off drain plug #110
Or maybe a trip to the dealer for a new tractor ....
/ Rounded off drain plug #111
I was going to suggest keep pouring the heat to it.......either it will break loose or the tractor will eventually burn to the ground. Either way way the plug will no longer be a problem! :D
Kind of need to tractor :D
Currently working on getting the tire tube replaced, and my truck decided to be problematic, cylinder misfire again. Problems pile on.
Once i get that situated, get the tube replaced, then I'll run the tractor up to a weld shop and see about getting a nut welded on and see how that goes.
/ Rounded off drain plug #113
:drink::cool2:.....
/ Rounded off drain plug #114
Please start seperate threads on the misfire and the tube! A few hundred posts and we'll get those solved for you also!!!! :laughing:
/ Rounded off drain plug #115
Hope the OP does not bail out on this thread though...... NOW I NEED to know what finally happens to that plug!
/ Rounded off drain plug #116
Don't let go of this thread though...... I NEED to know what finally happens to that plug!
TBN 6,000,000th post I got the plug out, Now what ...:)
/ Rounded off drain plug #117
If you weld a nut on the plug, you still have the tight space to get a wrench into, and the wrench may slip.
Instead, weld on a bar that can serve as a handle, or for a hammer to hit, where access is better. Drill a hole in the bar that the rounded plug fits into, then weld.
Bruce
/ Rounded off drain plug #118
Bruce
Or use a larger nut that fits over/around the plug completely and just weld the inside of the nut to the plug. Then it isn't hanging down any more than the plug is now, and will allow a larger wrench.
/ Rounded off drain plug #119
You're making this more difficult by having to drive the tractor over to a weld shop to weld a nut onto the plug. Just remove the plug and run that over to the weld shop. :thumbsup:
/ Rounded off drain plug #120
I know a lot of people use mityvacs for engine oil and transmission oil change. Could that work here to get the old fluid out?
I've used my little HF $5 hand pump to take a half quart out of my VW when they vastly overfilled it.
2005 MACK GRANITE CV713 T/A DUMP TRUCK (A64276)
2005 MACK GRANITE...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2006 Lexus ES 330 Sedan (A61574)
2006 Lexus ES 330...
New/Unused Landhonor Hand Chain Lever Hoist (A65583)
New/Unused...
Landhonor Mini Skid Loader (A66285)
Landhonor Mini...
