rototilling garden patch
/ rototilling garden patch #1
nickmech
Whatcom County, Wa.
So I found a good deal on a used Howard rotovator. It is an offset model and I noticed when tilling I start to run off at an angle to the right instead of going in a straight line. This messes up what I have tilled. The tiller is set straight at the 3pt. Is this common with offset tillers or is it just my operating? Also the gearbox being offset causes quite an angle to the pto shaft u-joint. The slip clutch has a couple bent studs and missing springs from previous owner. Where do you get parts for these cheap.
/ rototilling garden patch #2
the frame is likely bent, just straighten it and you'll still have a good deal
/ rototilling garden patch #3
Can you not steer while tilling? I have a reverse tine tiller and I can steer pretty well while tilling. Is this not true for a forward type tiller?
/ rototilling garden patch #4
some tillers have the gear box that moves when you off set - is yours that way?
(30) 3"x9' Steel Posts (A66408)
(30) 3"x9' Steel...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2015 Global M3 Street Sweeper (A64556)
2015 Global M3...
2009 FORD F-450 SUPER DUTY (A65643)
2009 FORD F-450...
2005 SBX-5 Box Blade Tractor Attachment (A61572)
2005 SBX-5 Box...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A65643)
2004 FORD F-350...
