rototilling garden patch
/ rototilling garden patch #1
nickmech
Whatcom County, Wa.
So I found a good deal on a used Howard rotovator. It is an offset model and I noticed when tilling I start to run off at an angle to the right instead of going in a straight line. This messes up what I have tilled. The tiller is set straight at the 3pt. Is this common with offset tillers or is it just my operating? Also the gearbox being offset causes quite an angle to the pto shaft u-joint. The slip clutch has a couple bent studs and missing springs from previous owner. Where do you get parts for these cheap.
/ rototilling garden patch #2
the frame is likely bent, just straighten it and you'll still have a good deal
/ rototilling garden patch #3
Can you not steer while tilling? I have a reverse tine tiller and I can steer pretty well while tilling. Is this not true for a forward type tiller?
/ rototilling garden patch #4
some tillers have the gear box that moves when you off set - is yours that way?
2000 Ford F-750 Debris Truck, VIN # 3FEXF75H8YMA01188 (A65563)
2000 Ford F-750...
2015 Audi A4 AWD Sedan (A61574)
2015 Audi A4 AWD...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
2005 MACK CHN613 (A65643)
2005 MACK CHN613...
KALMAR AC P50BX-PS WAREHOUSE FORKLIFT (A64276)
KALMAR AC P50BX-PS...
Cedar Swing (A65583)
