Replumbing with PEX
/ Replumbing with PEX #1
Boondox
Elite Member
Craftsbury Common, Vermont
Deere 4044R cab, Kubota KX-121-3S
Split this off from the COLD! thread in Related Topics as there was some interest in my use of PEX to replumb my 160 year old house.
Here's a shot of my homemade hot water manifold. I used individual runs of PEX to every fixture in the house, with each controlled by a ball valve.
Pete
Connection with copper line
A shot of a connection between the PEX and one of the few copper lines I didn't replace. I used the red fastener to mark hot lines and blue for cold.
Pete
PEX tool
Sort of a three-jawed expanding chuck. You fit a splice over the end of a run (the red piece), slide the tool inside the PEX, squeeze the jaws together to stretch the PEX to a larger ID. Close the jaws, slide the tool further up the pipe and repeat. Usually three tries does it for me. Then remove the tool and slide the expanded PEX over a fitting and hold it for a couple of minutes while the PEX' memory restores its original size. Heat speeds up the shrinkage.
Pete
Both manifolds
Here's a shot of both hot and cold water manifolds. Each ball valve controls one fixture in the house. In many cases I was able to snake the PEX tubing right thru the walls using the space left by the old copper pipes that were removed.
I also have a couple of valves that allow me to put the house on gravity feed in case we lose electrical power. Between this setup and the woodstove heating, we were very Y2K complaint!
Pete
/ Replumbing with PEX #5
Re: PEX tool
Thanks Pete. Is this that expensive tool that you previously mentioned? How much is this tool if one wanted to purchase it?
I noticed you retained the main portion of the 3/4" copper supply line....any reason why all copper lines couldn't be replaced with PEX? What prevents this main copper line from freezing up and cracking?
Thanks for all the pics....these are very helpful and already generating some ideas on how I want to re-run some of my water lines.
.....Bob
/ Replumbing with PEX #6
The "This Old House" show has been using PEX for their last few projects. The plumber just loves it.
/ Replumbing with PEX #7
Thanks, Pete.
What kind of arc can you put into that stuff before it kinks? I have a few tight spots to work in.
Paul
I have a couple of 3" radius curves. Got around the kinking concerns by simply running the PEX inside an electrical conduit elbow.
Pete
Re: PEX tool
Bob -- The tool cost about $400 when I used it a few years ago. I was lucky enough to have a friend who had already bought one, but like I said our local heating and plumbing service rents them out pretty reasonably.
I only kept a few short copper lines: a short run of 1/2" from the basement sink to the washer (that was the run that froze but never burst when the window broke), another from the basement to the shower fixture, and a pair of 3/4" lines the last foot or so to and from the hot water heater. I was worried about the heat but it turned out to be a non-issue.
The manifolds were made from 1" copper line with Tees leading to 1/2 or 3/4" ball valves depending on where the line was going. Wirsbo offers pre-made manifolds that are MUCH more compact than what I made, but I'm basically cheap and needed to impress the wife with my manly skills. Also, ball valves are easy to rebuild if that ever becomes necessary. The manifolds are mounted well away from the cold outer wall, and waste heat from the water heater provides additional protection from freezing.
We have a 1" PVC pipe running from the springhouse 1/4 mile up the hill into a 400 gallon cistern in the basement. From there a shallow well pump leads to a pressure tank, and from there to the cold manifold. I have a 1" line from the cold to the water heater, and another coming back from the heater to the hot manifold. If we lose power, I close a ball valve to isolate the cistern, another to isolate the pressure tank, and open a third to allow spring water to go directly into the cold manifold. Not as much pressure as the tank gives, but slow water is better than no water. Also, at the end of a long drought when the spring has gone dry, I can use these valves to let the pressure tank push water from the cistern back up the water line far enough to get the siphon effect going again.
Pretty slick!
Pete
/ Replumbing with PEX #10
Re: PEX tool
Thanks for the clarification Pete. Also, if I might add, this is one of the slickest plumbing jobs I've seen, definitely on par with work from some plumbers I know. /w3tcompact/icons/wink.gif
.....Bob
/ Replumbing with PEX #11
I have some of this in my house and it appears that I'm getting a pressure drop with it that I don't have with the copper. I have not had the time to see if this really a correct accessment on my part or not ..(there could be some other reason ) ... What kind of pressure lost is associated with PEX compared to Copper ... and what is the difference ....
Thanks,
Leo
/ Replumbing with PEX #12
Unless the inside diameter of the pex is less than the copper there should be no pressure drop compared to copper, to the contrary flow should be even greater due to not having any 90 deg connections.
/ Replumbing with PEX #13
I agree with you and that is what I would have thought ... so I just checked and found the mat'l I had thought to be PEX was not PEX .. instead it is a stiff plastic. This is on a sink feed line and I think that the diameter is to small and that is causing the reduced flow and in this case, pressure lost ... I have replaced some with copper feed lines and that does much better....
Thanks
Leo
/ Replumbing with PEX #14
Re: PEX tool
Pete,
That is a great looking. I have read about PEX in the past and it is interesting to hear some first hand experiences. Sure would speed up the plumbing rough in on new construction. With an older home like yours it had to save a lot of walls that would have been opened up to install copper.
If anyone is interested, Fine Homebuilding magazine has an article about PEX in the issue that I received today. (March 2003, Issue 153)
MarkV
Re: Connection with copper line
This particular line froze last night. The PEX swelled up and held. The copper line split in the middle. So much for my theory that short runs of copper were okay!
Pete
Hazmat -- Nope. It was in reference to the pic posted on 01/23/03 06:16 PM. Same line in that pic.
Pete
/ Replumbing with PEX #18
Sorry to hear that, Pete. I guess all you northeastern folks will be glad to see Spring this year.
Seasons in New England are a little different than other places, Bird. Before spring comes Thaw, then Mud, then Bug Season. Spring comes around mid-June.
I never understood Vermonters who take vacations elsewhere during those wonderfully snowy winter months. If ever there was a time to be away, it's the transition between Mud and Bug seasons!
Pete
Bobcat T66 (A60462)
Bobcat T66 (A60462)
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - 2018 - Tier 2 - Pump Takeout (A63689)
Kubota V3600-T-E2...
2011 GALYEAN 130BBL (A65643)
2011 GALYEAN...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
2016 CATERPILLAR 926M WHEEL LOADER (A65053)
2016 CATERPILLAR...
Bobcat S66 Skid Steer (A63688)
Bobcat S66 Skid...
